944turb0's Avatar
Send a message via AIM to 944turb0
HUGE oil leak ;_;
I have an '87 all stock 944. It had sat in storage for 10 years before I bought it and drove it pretty hard on summer weekends. Just this fall, I took it on the freeway and I smelled oil burning after about 30min. I pull over and it's just dumping oil from the front of the engine but I couldn't tell from where.
The motor was running smooth, wasn't overheating. Ran just as usual when the leak happened. Babied it home, stopping to add a quart about every 5min. The next day the first snowfall buried it and i haven't had a chance to look it over due to the cold. I'll go in depth come spring. Is this related to a common failure? I really hope it's not a seal
Old 01-04-2009, 03:52 PM
sup
Old 01-04-2009, 04:09 PM
That Guy
Techno Duck's Avatar
What corner of the car is the oil leaking out from, passenger, center, drivers side?
My first guess is the oil filter gasket blew out.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-04-2009, 04:12 PM
Greasy Member
many944s's Avatar
If it sat for that long, it could be one of the front seals. It's not really that bad of a job. Besides, for a car that hibernated for 10 years, it could definitely use a new front end job!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 01-04-2009, 04:13 PM
944turb0's Avatar
I'm not sure where exactly it was coming from, the timing belt was flinging it all over the front. Also, it only leaks when it gets to operating temp.
Old 01-04-2009, 04:20 PM
They have snow in San Mateo! Yippee!
Good luck, George Beuselinck
Old 01-04-2009, 04:29 PM
Hes not from California, lol.
Old 01-04-2009, 04:46 PM
944turb0's Avatar
oh yeah, borrowing a friends account
Old 01-04-2009, 04:56 PM
I would guess it would most likely be a front oil seal if the timing belt is "flinging" the oil around. Make sure to replace the timing and balance belts at the same time. Better yet, make sure everything at the front of the engine is fine, including the water pump.
Neil
87 944S
http://guns.claasen.us/
Old 01-04-2009, 05:44 PM
944turb0's Avatar
is the front seal a pain to replace?
Old 01-04-2009, 06:04 PM
pauloregon's Avatar
Depends on how you define "a pain". It's a lot of work to remove all the stuff to get access to the front of the engine, at which time you might as well do the balance shaft seals, crankshaft seal and pump sleeve, as well as the camshaft seals. But, once you get all the cruft out of the way, it's rather simple to replace an o-ring here, slide an onion-skin seal there, etc. Just make sure to watch out for the oil seal details, using the right one on the right shaft, etc.
1985.5 944 NA 5spd 195k miles
Daily driver since I bought the car in 1990
Currently getting a top-end rebuild (head gasket)
2005 BMW R1200GS motorcycle
Old 01-04-2009, 08:21 PM
Feelin' Solexy
Tishabet's Avatar
Agreed, this job is approachable to the average shady tree mechanic. Check out Clarks-garage.com for a good rundown of the job. While you're dissected down that far you'll probably want to replace the water pump as well unless you know the current pump was replaced recently. You'll also want to clean/degrease the area after the seals are done and replace your timing and balance shaft belts; if these have any oil on them they are no good and need to be replaced ASAP.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 01-05-2009, 08:32 AM
944turb0's Avatar
"replace your timing and balance shaft belts; if these have any oil on them they are no good and need to be replaced ASAP."
Oh wow that's awful
Old 01-05-2009, 02:08 PM
Feelin' Solexy
Tishabet's Avatar
It's not that bad, you're going to have to take the old ones off in order to replace the seals anyway... the new belts should run you a total of about $65 for both. Definitely something you can do yourself.
Grant
Old 01-06-2009, 08:11 AM
944turb0's Avatar
Oh that's not so bad I guess. I just don't know how to tear it all down and what tensions and etc. Is there a guide on here that would help?
Old 01-06-2009, 01:19 PM
Feelin' Solexy
Tishabet's Avatar
Check out http://www.clarks-garage.com for excellent write-ups of how to do all of this work. I've done the exact job you're looking at doing (seals, water pump (optional), timing belt, counterbalance belt) using the instructions from that site.
Grant
Old 01-06-2009, 03:51 PM
TibetanT's Avatar
subscribing
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 01-06-2009, 08:40 PM
944turb0's Avatar
Great site thanks!
so are there any oil lines/hoses that could of failed instead of a seal..?(really hoping)
Old 01-07-2009, 02:05 PM
ernie9944's Avatar
944 turbo buy yourself the haynes manual for your car best investment there is been using mine since 1983 and my car is still on the road defying many so call boys racers good luck fixing that leak I agree with mericet good tips he gave you ****** ERNIE 9944
Old 01-08-2009, 02:37 PM
944turb0's Avatar
I just found out that it was front cam cover seals that went. A local 944 guy quoted me $722 parts and labor for doing the timing belt, the seals, and the water pump, which sounds really reasonable
Thanks for your input guys
Old 02-12-2009, 04:13 PM
