83 944
Hi I'm new to this so I don't know if it has been covered already.
I have an 83 944 and every time I try to start the car, it will crank but will not start. After the second attempt it will kill my battery completely. Car will start if I jump it with another car. I have removed battery while car is running and car will stay on. I leave it running for a while and then shut the car off and try to get it going again it wont start back up. I have tried this with a used battery and a brand new one |
you may be told not to do that
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
meister member
first check for spark by pulling a plug and laying against the engine. Crank the engine and observe the spark across the gap.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
i have read you should not remove the battery from the running circuit.
