Architecture & Porsche's
My car's leaking fuel at the tank: how to remove the pump shield...
My car's incapacitated across the street on a lift: leaking fuel while the car's running at the bottom of the tank, hidden by the stone shield that, I assume, hides the pump.
Anyone know how this shield comes off? Shop can't figure it out. Any idea what they're most likely to see?
Mark
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 01-14-2009, 12:49 PM
Send a message via AIM to ScoobySteve
Mark
Time for a new shop...
There's a bolt that holds the strap containing the cover. Clark's has a well-written procedure:
http://www.clarks-garage.com/shop-manual/fuel-10.htm
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 01-14-2009, 03:30 PM
TibetanT's Avatar
Mark:
What year and make is your car?
If 944n/a late, you should see a strap holding the entire gas tank cover on. Using a long extension you remove the entire cover. Then, to remove the fuel pump from the bottom of the cover you loosen the large hose clamp via a screw. Most times these things are rusted, so you may have to use WD-40 to get it to move.
So, yes! The stone shield does hide the fuel pump which is held on by a large hose clamp. The adjustment screw, for this large hose clamp, on my car was very hard to see. The factory people placed it at the bottom near the cover, so it took me a good hour to figure that out. Also, if the stone shield has road dirt on it, or if it has been covered with undercarriage sealant (usually black) it will be a little difficult to see the hose clamp on the outside of the stone shield.
My best guess for the fuel leaking is there is either a seal, or seals, gone bad, or one of the hoses needs to be replaced. If I remember correctly, there is one hose going from the bottom of the tank to the fuel filter and another hose going from the fuel filter to the fuel pump. Bango type fitting there.
Hope this helps.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 01-14-2009, 06:05 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
hi, the most likely scenario forthe metal fuel tanks is that rust has attacked the tank behind the securing strap, as that band has a foam anti-vibration inner surface that helpfully holds water against the tank..
You can repair it by loosening the band whilst supporting the tank, and use petro-patch to seal up the hole. Better is to get the tank out, a PITA, and have it sealed internally, or replace it.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 01-15-2009, 04:29 AM
GostRidr's Avatar
This happened to me last year after filling up the tank! Quite a mess! In my case, the little rubber hose from the tank to the pump had cracked. Hopefully, that was all you needed too. I have to agree with Scooby though. I don't remember having great difficulty in discovering that the strap is bolted in on one side. Let us know what the result was.
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 01-15-2009, 10:35 AM
By the time I got home my massive fuel leak had stopped. I put the car up on the lift anyway & pulled the lower pan to look for obvious signs: nothing obvious.
I'll plan on a new pump & feed hose & will rebuild all the flexible fuel hoses under the car in a month or so.
Odd: Porsche lists the same pump for turbo vs NA.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 01-15-2009, 11:27 AM
