I have power steering again! Question:
So I was putting on the new (used) pump that I received today and noticed that the fitting that connects the hose from the reservoir didn't match the one I had, and that the hose wouldn't bend to properly feed it. Is this an aftermarket fitting?
One I received http://www.theexitwound.com/944/pspump2noz1.jpg One I had prior http://www.theexitwound.com/944/pspump2noz2.jpg As you can see, the one i had comes out and uses a 90 degree angle to feed the hose, the one I received on the pump did not. I changed them out so there's no problem. I'm just curious why there was a difference. Ah to have power steering again. Been without it since October. Installed http://www.theexitwound.com/944/pspump2installed.jpg |
You need the new hose and get a new reservoir tank-the filter clogs>
http://forums.pelicanparts.com/uploa...1238705824.jpg Of course you could take off your old fitting and use the old hose. GL John_AZ |
Wow. The power steering reservoir and the hose have been upgraded? Is the filter in the bottom of the reservoir? I had no idea.
Pelican says that what you're showing me is for 1987-. I have an 86. Have the 86's been upgraded to the new design? |
Home > 924S/944/968 > Suspension > Porsche 924S/944/968 Steering System Porsche 924S/944/968 Steering System - Page 2 Power Steering Parts Power Steering Hose 944-347-445-05-M260 Power Steering Hose, Pump to Reservoir, 924S, 944, 944S/S2, 944 Turbo, 968, NOTE: also requires purchase of 999-230-357-02-M260 Hose Fitting for cars through 1989), Each Brand: OEM [More Info] $40.50 999-230-357-02-M260 Hose Fitting for Power Steering Hose, Each Brand: OEM [More Info] $6.00 Power Steering Reservoirs And Parts 928-347-015-05-M103 Power Steering Reservoir, Includes Reservoir Cap and O-Ring, 924S/944/968 All (1983-95), Each Brand: ZF [More Info] $19.75 From: http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_SUSstr_pg2.htm Looks like it fits all through '89 The PS reservoir should be changed if it has not new. The filter clogs. GL John_AZ |
| All times are GMT -8. The time now is 03:32 PM. |
