-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   new 924 steering issue... (http://forums.pelicanparts.com/showthread.php?t=466813)
porsche189 04-02-2009 08:56 PM
I just bought a 924, but it has sat for about a year, and it has loose steering, it has play when going over a bump slowly and when going around 25 mph, both accellerating and coasting. what do I need to check first, for front end problems? know where to find parts? are they expensive?
running_cold924 04-04-2009 05:30 AM
not very expensive, mine ate the outer tie-rod ends, so i replaced them and the inners were fine. got them from www.*********************** and its free ship over $50! ball joints should be okay, but jack up the control arm and use a pry-bar under the wheel and check for movement up and down. may be best to have an extra set of eyes
porsche189 04-04-2009 09:45 PM
924 tie rods
i jacked it up, checked the outers they seem ok, but the inner tie rods have movement and a lot of play. do i need to order the tie rod attachment, or the whole set up? thanks for the diagnosis.
Steven
running_cold924 04-05-2009 05:49 PM
probable just the inners, but if it were my car, i would do inners and outers both, just do it once and be done with it. then get it aligned and your good to go!
