Something broke
Im pretty sure that something broke on my 86' but I am not sure what.
I was driving it to the gas station today and got cut-off by a bus! I slammed on the brakes (which locked up, no abs) and pushed the clutch in. I was wearing my skate shoes which are kinda big, and when I hit the brakes my foot hit the gas as well. It only rev'ed to like 5K and then I let off. After it was over, I put her into first and started to let out the clutch, but then it sounded like I missed a gear and it started grinding (i was def in first tho) I tried again and it went into first fine, but then shifting into second it did the same thing! I pushed the clutch in and all the sudden the engine started to dog. It dipped below 200 rpm (the needle was all the way down on the tach) and I gassed it before it could stall, it reved slowly, then gave up and stalled (first time ever it has stalled for me). There was a noticable amount of smoke coming out from under the car, but im not sure where, somewhere between the engine and where the driver sits. It started fine and seemed to drive fine but was less responsive as usual. I limped it home and checked it out but cant see anything out of the ordinary. It starts fine, but im not sure where my oil pressure is at because my sender hasnt worked since i took it out of storage.
Any ideas what might have happened? Im pretty worried.
Old 04-14-2009, 02:32 PM
could be the clutch roasted when you revved and clutched at same time. what did it smell like? clutch roast has a very distinct smell
Old 04-14-2009, 02:51 PM
It didnt smell like clutch, but the wind was blowing pretty hard and I might not have smelt it.
Old 04-14-2009, 03:05 PM
Feelin' Solexy
Tishabet's Avatar
Do you know if the clutch in the car is original? Now that it's home, aside from the "less responsive" thing are there any other running and driving or idling issues?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 04-14-2009, 03:27 PM
Under the car
The engine may have reved higher and the tack wasn't fast enough to show it.
Old 04-14-2009, 04:33 PM
I would guess that it is original, I really have no way of knowing besides crawling under and checking the inspection hole.
Matt- I dont think the engine reved much higher then 5 because my car is pretty loud and sounded like it did at 5 g's
Old 04-14-2009, 07:40 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
these engines have a rev-limiter anyway, so would not allow it to over-rev
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 04-15-2009, 02:29 AM
Would frying the clutch cause the engineto stall tho? Cause i had the clutch in when it was stalling.
Old 04-15-2009, 07:33 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Well the rubber centered clutch could have started to disintegrate. A large chunk could be jammed in between the clutch and flywheel or housing. This could cause a lot of drag that will try to stall the engine because even with the clutch plate disengaged, the rubber will still be rubbing on the flywheel. This will also cause the rubber to burn/melt and smoke.
There are inspection holes that have (should have) plugs. Remove these and look in, if you see any rubber debris then your in for a clutch job. Its not that hard in reality, just takes some time. And you could even get away with just a disk, but for the effort its worth doing the whole thing.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 04-15-2009, 11:41 AM
