Windshield Washer Check Valves??
i know rthat there is a clogged check valve under the hood on the passenger side of my car ( T-Valve).
are there any others that i dont see? the water runs all the way to the T and before i order a part id like to make sure im not missing seeing one somewhere on the drivers side thanks |
i have one for each sprayer on both of my 968s
There's an L shaped one for the driver side. I believe they have different rates to keep the spray the same for both when the flow comes from the passenger side. If they both weren't there, the passenger side would flow more.
L-shaped on the driver's side. T-shaped on the passenger's side. They are different rates and considerably cheap on our host here (Pelican Parts).
I replaced the entire system, minus the pump, for like 20 bucks. Included hoses and everything.
'83 944 N/A '88 Ford F-150 4WD - Does Everything '99 300M - Daily Driver, headlights just polished! '85 34' ITASCA MotorHome, built-in blender baby! '89 Supra - Black - Future 400hp NA sleeper. |
