Speedometer "popping"
When I'm driving, usually when i'm keeping a steady speed, my speedometer will make a popping noise and shoot up instantaneously about 20 mph....It sounds like a relay is clicking, any idea what this could be? bad ground maybe?
'87 Guards Red 924S - First Porsche - SOLD 5/21/10 '67 Red VW Beetle - Restored by me and my dad, 2115cc motor. ![]() '87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE '92 Ford F150 - Winter truck '04 Yamaha R6 |
Proprietoristicly Refined
Your speedometer cable needs oil. Remove the left guage cluster carefully. Put your hand and wrist in the hole-press the speedometer forward 1 inch. Unscrew the speedometer cable from the speedometer. NOW--your car has the "upshift" indicator on the right guage cluster. It is connected to the speedometer by 2 thin wires. The wires plug into the right guage cluster--pull gently out.
Grease cable with cable grease/graphite stuff Put a drop of oil on the speedometer cable "nose". You can put a small screwdriver in the hole to turn and help the oil work in. Do not cross thread the speedometer cable end on the speedometer body. When you are done--apply first aid salve to all the cuts on your hand and wrist. Great buy on the parts! GL John_AZ 1988 924S + 1987 924S Last edited by John_AZ; 06-05-2009 at 04:04 PM.. Reason: Oil the speedometer "nose" |
Thanks a lot! I'll have to get on that ASAP...probably when im installing my seals and timing belt and sway bar and everything else under the sun =]
