I need to replace Timing and Ballance Shaft Belts, Waterpump, Clutch Master Cylinder and both sides Front Wheel Bearings on my 1984 944 NA. What should I expect to pay a good Porsche mechanic using Porsche parts for Labor and Materials? I am a new Porsche guy and seems like I am learning the hard way. Your advise will be appreciated. Thanks.
Figure about $1500 if a good, honest Porsche mechanic does it.
Good luck, George Beuselinck |
Greasy Member
^ Good call, though don't be supprised if it ends up a little more.
Since the rear timing cover will be off for the pump replacement, it wouldn't be a bad idea to replace the front seals (while someone is in there....) I recently had a 944 in the shop a similar service: Pump, belts, rollers, seals & cam tower gasket Front wheel bearings cost aabout the same as the cam bolt & cam tower gasket, but the wheel bearings require less labor, Bottom line was $1550. -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
