🔧 944 Rough Cold Start — Easy Fix I Missed
My ‘87 944 NA was cranking fine but stumbling on cold starts. Turned out to be a weak temp sensor (CTS).
Swapped it, cleaned the grounds on the intake, and it fired right up the next morning — smooth idle too.
These little things make a big difference! Anyone else forget about that sensor?
Old 07-24-2025, 12:30 PM
Nice work on cleaning the intake grounds too between that and a fresh CTS, you probably gave the DME the best signal it’s seen in years.
Old 08-12-2025, 12:10 AM
