connecting sterring shaft
so after all the assembling and putting things back together i completely overlooked the steering shaft.......
is there a easy way to reattach it with everything bolted up or do i have to take the cross member back down to connect it?
1983 944 Guards Red (87' Implant Complete)
Old 07-08-2009, 07:36 PM
crossmember back down. sorry heh
Old 07-08-2009, 09:37 PM
Just thinking out loud
mattdavis11's Avatar
Loosen the rack, unbolt it if you have to. It'll slide in. Cross member can stay put.
91 FJ80
84 Ram Charger (now gone)
Old 07-08-2009, 09:47 PM
Hold on, I see you have an 83, and just automatically assumed you had a manual rack, which hopefully you do. If so, see above.
91 FJ80
Old 07-08-2009, 09:51 PM
haha, yea its a manual automatic wasnt offered on first yr model of our lovely car. as it shouldnt have!
i was hopin there was some magic grease or somethin i could use but i suppose lossening the rack would be easiest method, i really dont want to drop the member again
Old 07-09-2009, 11:06 AM
TexasBlake's Avatar
Push the rack up into place. Install the two mounting bolts just a few threads in place. Leave the two driver side bolts out. Reach up and grab the steering shaft. Slide the steering shaft into the back of the rack while pushing the rack towards the back of the car. Install the bolts for the steering shaft to 22 ft/lb.
Old 07-09-2009, 12:41 PM
Zero10's Avatar
Send a message via ICQ to Zero10
There is no reason to drop the crossmember for this, the rack comes off and it can be lowered then install the steering shaft onto it while you re-install it. Super easy job actually (spoken as a guy who has forgotten this exact thing twice now)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 07-09-2009, 03:59 PM
