Official Sponsor
favorite methods for cleaning head gasket surfaces?
hey guys whats the preferred method for cleaning the gasket surfaces on the cylinder head and block prior to installing the head gasket ?...I am thinking of just putting on a new head-gasket then plopping on the donor head any words of wisdom?
putty knife and gummout?
1988 - 924S Guards red, auto trans |
Custom User Title
Aluminum is so easy to scratch, I'd worry about a putty knife. Gotta be really careful.
We did my kid's cam tower gasket a few weeks ago (on his 951) and what really worked great was a wire brush attachment for my drill. It really did a great job - made it look like new. The downside is that it flings gasket crap all over the place. I s'pose with a head gasket, that might be less a problem.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Official Sponsor
ooh ...maybe a good job for the DREMEL
Custom User Title
If they have a wire brush attachment, yeah, that'd be great. My drill is big and it was kinda difficult to maneuver around in there. A dremmel would be much easier.
Proprietoristicly Refined
Wisdom? six years on the board and you expect new advice? ![]() I will expect your "donor head" to be fresh and ready to go from the machine shop. Use SeaFoam before you drain the oil and filter for a few miles. Cleaning surfaces properly is 4 to 6 hours. Do not remove the carbon ring at the top of the cylinders. Depending on the amount of carbon on top of the pistons, you may NOT want to touch the top. You may cause more chunks of carbon to fall between the piston and the walls----causing scratches. YMMV Clean out the deep rear galleys at the back between the cyl wall and block. You may find antifreeze/coolant deposits-use a LED lamp to check. Razor blades and acetone done very carefully will get the last of the dried on stuff. MORE WYAIT Have the ICV rubber mounts. With the intake off, best time to replace. Replace AOS "O" rings Hoses--hoses--hoses New heater control valve and short top hose New cam gear bolt Check the lifters properly---- http://www.benms.com/944lifter.html on and on and on....... GL John_AZ 1988 924S + 1987 924S |
Official Sponsor
s&*%$#@... I am going to soak my lifters right now
Who's got the SEAFOAM? Advance AUto Parts or West Marine?
I use these for cleaning any surface:
They're 3M brand and you can buy them at any parts store. I forget what they're called. They're very soft but they are excellent at cleaning gasket surfaces. I've always used them with a pneumatic die grinder like pictured, but now that I have a dremel I might give that a shot.
Your frustration level "s&*%$#@..."is just about right ![]() By the time you finish you may need a blood pressure monitor ![]() John_AZ |
Back from Beyond
Acetone. Plastic ice scraper.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
I used one of those green pads from the kitchen. Did a good job, but took close to 2 hrs!
dolor et pavor Copyright |
winter-hater club member
thin, flexible razor blades and some rubbing alcohol. replace the blade often. take your time.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Thin razor blade is about all we use at the shop here.
- Elliott Grafton - 944Barn |
your average wrencher...
x2 on the razor-blade, just keep it perpendicular to the surface
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
Don't you mean parallel to the surface?
84, 944 Silver--Crashed and burned. 87, 944S White--Daily driver |
Official Sponsor
I have never used the Seafoam... anybody have experience with it?
Stabilizes fuel cleans injecters etc... also cleans oil?
I would never use a flexible wheel to clean critical mating surfaces like a head or cam tower, even water pump. Since they are flexible, they do not create a flat surface. They round over the edges and create high/low spots on the surface.
Machine shops use a fly-cutter when resurfacing, but of course that's out of the realm of possibilities when doing most jobs. I simply scrape with a razor blade, then use 120-grit paper on a hard (small) sanding block, then finish with 400-grit. You don't want a mirror like finish on the surfaces, it needs to have a satin look for the surfaces to be pressed into the gasket material. There's an art to making things flat, some believe in it and some do not.
'83 944 N/A '88 Ford F-150 4WD - Does Everything '99 300M - Daily Driver, headlights just polished! '85 34' ITASCA MotorHome, built-in blender baby! '89 Supra - Black - Future 400hp NA sleeper. |
nope, nearly perpendicular. i hold the razor blade at about a 70 degree angle, roughly, and take a lot of time. i buy the big box of blades and go through at least 20 of them.
Cars & Coffee Killer
I just did a whole top-end gasket job on a marine Chevy 350. We used the scotch-brite pads that a picture is posted of above. They are plastic and minimally abrasive. Still, be careful to keep them perpendicular to the mating surfaces.
It took my father-in-law and I 11 hours to clean up the engine (so 22 hours of labor). I'd expect a 4-cylinder engine to take roughly half the time. We did everything though, cylinder head, top of block, intake and exhaust manifolds. I've been known to use a plastic putty knife on aluminum motorcycle engines...
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
hey, I'm posting this here rather than on my thread about head gasket change as need more help!
I am leaving the main block and pistons in the car and the block surfaces and piston heads (to me) appear very dirty. What is the best method to clean things, how can I avoid getting crap down between the wall and piston? Or is this not critical and if I clean the piston at the top of its stroke and then draw it down any dirt on the cylinder wall could be cleaned off with a suitable soft cloth / pad??? scotchb pads sound good will get some of them though!
1991 944 Turbo 2012 VW Passat 2008 Mini Cooper |
I used a gasket scraping tool and did it carefully. Head has been on for 12 years now. After scraping it clean I used 3M cleaner to remove any oily residue. Acetone would also work well.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
