dewolf's Avatar
Ignition rotor help
Ok, thought I'd change the cap and rotor. Top clip undone ok but the bottom one crumbled around the cap. Went to pull off the rotor and it to crumbled in my hands leaving a brass piece over the shaft. Is the brass piece part of the rotor and does it have to come off as well?
Old 08-18-2009, 06:02 AM
Send a message via AIM to Icey1174
There should be a set screw that holds the rotor on. Remove the set screw and remaining pieces of the rotor. Can you post any pictures? Do you have a new rotor to compare with?
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 08-18-2009, 07:19 AM
That Guy
Techno Duck's Avatar
Brass sleeve is part of rotor and needs to come off also. Some cheap aftermarket rotors don't come with one though. Make sure you remove setscrew and remove the sleeve (channel locks or flat tip screwdriver).
Old 08-18-2009, 08:13 AM
dewolf's Avatar
cool, thanks guy's. Thought as much.
Old 08-18-2009, 03:43 PM
