jasonmx5's Avatar
Oil leak
After purchasing my '83 a few weeks ago, I've finally had time to get her running (albeit rough - I have another thread for that). Now that it is, I've discovered a fairly significant oil leak that I have yet to be able to pinpoint. Only occours when running, and appears to be coming from the rear of the engine closest to the passenger side. Any ideas if this is a common leak area? What to look for first? Haven't had a chance yet to crawl under the car to see if I can determine where the leak is originating from.
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 08-20-2009, 08:05 AM
rear main seal trickling
balance shaft seals
cam tower gasket
rear cam tower cap gasket
they all kinda drip oil to the rear pass side of the engine.
Old 08-20-2009, 08:09 AM
Redline Racer
HondaDustR's Avatar
Number 9 on this pic often goes bad and is really easy to replace. It's right over the rear cam bearing, wich is supplied with oil pressure, so that would make a pretty good leak if the gasket is bad.
Number 3 could be bad as well. A bit more difficult to replace, but not bad.
It could also be the RMS or the balance shaft housing/rear housing plug O-ring as mentioned.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-20-2009, 08:31 AM
Send a message via AIM to Icey1174
Rear cam gasket is the most common culprit. It drips right onto the exhaust manifold and you will eventually see some smoke. It's easiest to remove the cam to change the gasket. This way you can change the cam tower gasket at the same time. It's a pretty easy job and the gaskets are cheap.
My whole car leaked oil from everywhere when I got it. The rear cam tower gasket was the most annoying one.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 08-20-2009, 09:58 AM
jasonmx5's Avatar
this is a pretty significant leak. I looked at the rear cam gasket and it looked ok. A little damp, but not like the drip I'm seeing. In the course of running for 10 minutes, the oil puddle was 4-5 inches in diameter. That concerns me. I suspect head gasket or maybe rear main? Either would probably suck a lot worse to replace than the cam gasket, eh?
Old 08-20-2009, 11:09 AM
Proprietoristicly Refined
John_AZ's Avatar
Look at the REAR balance shaft/compensating shaft on the passenger side. It is below the exhaust manifold above the oil pan. The rear seal may be bad. If this is bad you will see a wide area of black oil/grease from years of dripping. A temporary solution is to clean the area and get silicone and gob it on/in for a while. No fast fix otherwise.
The RMS will leak straight down when the car sits and you can see the trail of oil on the rear oil pan.
GL
John_AZ
1988 924S + 1987 924S
Old 08-20-2009, 12:40 PM
jasonmx5's Avatar
GL
John_AZ
Good stuff. Thanks John
Old 08-20-2009, 01:16 PM
