mikeran's Avatar
Horn wiring question
If I understand correctly basically the horn sounds when the relay gets grounded. The metal strip on the turn/wiper assembly gets shorted to ground when you push the pad on the steering wheel, is that correct?
If so can anyone tell me what color wire in the plug is the one for the horn gound?
87 944 - Daily Driver - Son took it and now brought it back
Old 04-14-2010, 03:56 PM
one of gods prototypes
bell's Avatar
should be a brown w/white stripe for the neg horn trigger at the steering column, at the relay the 12v+ output is black w/yellow stripe.
use a multi-meter to confirm....
Brought to you by Carl's Jr.
Old 04-14-2010, 06:19 PM
mikeran's Avatar
Great thanks I will verify tonight when I am back working on the car.
Old 04-15-2010, 03:58 AM
