-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Installing wheel studs (http://forums.pelicanparts.com/showthread.php?t=498266)
jonvo 09-11-2009 09:20 PM
Is there enough clearance to change out the front and rear wheel studs without removing the hubs? I want to put extended studs on my car so i can run spacers. The reason i ask is because i just did my wheel bearings about a month ago, and i remember the rear hubs taking the bearing races with them. I really don't want to replace my new wheel bearings again.
drift a 944 09-12-2009 11:33 AM
bump. I'd also like to know.
924RACR 09-13-2009 05:40 AM
I'm pretty sure there isn't, especially if you plan on installing extra-long studs.
FWIW I have them too, on my racecar, with LOTS of spacer.
After installing - MAKE SURE to re-torque your wheels frequently, like every day you drive it or so, until they stop moving! We did it before every session on the racecar (well, actually we still do), and it took a few days (2 sessions per day) before they were done settling in.
DREDLOC 05-24-2011 03:14 PM
does anyone know i can find extended wheel stude for my 944 na?
i found a good deal on some rims but they are a little too big for the rear
i gor spacers but now i need extended studs with the same factory dimensions a
except length
please
anyone
