CV Joints- How?
My Passenger side CV joint is going bad (that clicking sound!) and I tried to take them screws out, but they were not budging. What tools do you need to take out the allen head screws? Obviously the allen head wrench, but that alone isnt doing the trick. I didnt want to turn the wrench with a hammer because Id probally strip the bolt. Would a power drill work, or will that be to much, will it fit even? Anything would be helpfull.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
Proprietoristicly Refined
8mm ---Triple Square---or Cheesehead---or XZN---or ....
You can get a set of 4 sizes at most autoparts stores for about $15. Poor cheap quality. Your can get a set from SnapOn or ???? (shop quality) for about $60. Napa--Sears ----The more you spend the longer they will last. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Make sure you tap them into the bolt head when you use them - much like an allen head, they will strip easily if not engaged all the way. Don't use a drill or an impact wrench - just a socket wrench, maybe with a length of pipe to extend the leverage if they are really stuck.
John is correct, the real name is triple square and it is 8mm. Make sure to clean the head of the bolt completely so that the triple square fits perfectly in the head of the bolt. Ensure that you are at 90 degrees from the bolt with your wrench or ratchet. If the PO torqued the bolts correctly you should be able to break them loose easily as the torque value for these is 30 ft. lbs. The CV bolts are not meant to be re-used so be sure to get new ones or even upgrade them to Ideola's secure bolts with locking clips. Good luck.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
You might substitute commonly available (well in the UK anyway) high tensile allen cap head bolts.
I got some black, allen cap head M8x50mm high tensile, 12.9, bolts, 10 bolts for £3.30, and some standard BZP shakeproof washers. The bolts should be high tensile, proper bolts with smooth untapped shanks, and using shakeproof washers is also dead important, as otherwise the bolts will back out the first chance they get. Last time I checked Porsche wanted £1.80 for each 12 point, or triple square bolt, not available until next week... cheers Rissole
944 Alpine White '89 2.7L |
one of gods prototypes
A little trick for stubborn axle bolts with damaged heads....
Heat, vice grips, AND the allen...heat up the head.....clip on the vice grips tight then turn that and the allen at the same time.....once they break loose you're golden.... Heat will make the biggest difference, propane will work fine just be cautious as always with the flame.
Brought to you by Carl's Jr. |
