Clean up? - secret Tootsie Roll stash
The insurance co. decided they want pics before they finish writing the policy. While taking pics of everything I can think they might want I notice:
then
To clean the rest I was thinking waterpic low setting or wrapping moist gauze around a piece of tongue depressor and the allis forceps to reach the far part of the cavity. Other suggestions?
88 944 na
07 335i
12 Cayman
Old 10-04-2009, 07:25 AM
75ohm's Avatar
What exactly is going on here? You have a bug issue with it hoarding tootsie rolls?
I'd use a bunch of lift off/goof off... soap and water and blasting likely won't get residuals...
www.rennwish.org
'88 944 NA - Red/Black with more tinkering done than probably needed.
Old 10-04-2009, 07:30 AM
No I just wasn't sure how much water I could blast in there. I didn't want to cause problems with the heater stuff there. The residue is currently soft and sticky so shouldn't take much. Just way too weird a place to keep your stash. At least it wasn't illegal stuff, just a sugar high.
88 944 na
07 335i
12 Cayman
Old 10-04-2009, 08:00 AM
ernie9944's Avatar
My god I've seen everything in there , dry leafs - sand -flies -pieces of paper but first time I see tootsies in such a odd place ADVICE look for the mouse,good luck with the cleaning what I use most of the time is a long thin rod with a small pieces of clothes soak in varsol migth work for you!just finish cleaning the engin bay on my new to me 968 ,what a knuckles skinner I'll advices not using any water if you can do otherwise.
Old 10-04-2009, 09:16 AM
slow944s's Avatar
You might try steam cleaning to desolve the gooo.
84, 944 Silver--Crashed and burned.
87, 944S White--Daily driver
Old 10-05-2009, 08:57 AM
VII VII is offline
Great post. It definitely made me smile. Reminds me that I should check my stash area for more than the leaves I can see.
Old 10-05-2009, 11:49 AM
Custom User Title
Dave L's Avatar
I found a partially smoked cigarette when I took my front bumper off. Not quite as exciting as tootsie rolls though.
Old 10-05-2009, 12:41 PM
Clean and dry
Waterpik worked great. Clean w/ less than 10 oz of water. But revealed drain hole was plugged, not really a surprise. Waterpik full blast took a bit and about 60 oz (repeat blotting w/ paper towel to adsorb) to clear the drain. Great feed back as it started to drip from underneath.
88 944 na
07 335i
12 Cayman
Old 10-05-2009, 07:55 PM
Arizona_928's Avatar
I found acouple cigs, and a torn up pack hidden under the intake manifold. they must've been their for awhile, they were pretty grimmy.
dolor et pavor
Copyright
Old 10-05-2009, 09:09 PM
