ignition lock hard to turn
So this morning, I got into my car and the ignition was hard to turn. I have to wiggle the key back and forth in order to get it to turn and start. The key isn't bent or anything. Anyone know what could have happened?
Avatar's are to SMALL.
LOL. Im having this VERY same problem!!! I think my keys are just worn out? Maybe yours too?
1986 951 - Wrecked. Being used for engine swap and parts. 1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts. |
This happened to me a couple days ago, but once i tapped on the cylinder and FORCED the key to turn, all was good..
GL, Ryan
1985.1 Porsche 944-Koni Adjustable Rear Shocks |
earwax solved my problem. could it be water? windshield deicer, then lube? the deicer destroys plastic parts, like window switches, maybe wd40 is better?
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Put a rag under it to catch the drips and spray brakekleen in it untill it comes out clean.
Then give it a liberal dose of graphite key lube.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
It works normally again all of a sudden. Maybe it is dirty inside. I will try cleaning it if it ever happens again. Thanks.
God this is driving me nuts! I hate fiddling with the key to get it to turn! How do I go about getting new keys? I if buy a new ignition switch does it come with keys?
dkbautosports.com
there is white grease on the pins inside the key switch . white grease gets old and hard after 20 years . just give it a shot of new white grease from a spray can or some wd-40 .
or try Caig Fader Lube - guaranteed not to mess-up plastic. Caig is electronics lubrication. All the audio guys use it.
Warren '87 944S "Tubes sound better" |
