What happens when you attempt to start it and it doesn't start? Does it crank normally or do you get nothing?
My friends call me, Top
It cranks normally, just won't fire.
Matt '87 924S |
Just thinking out loud
the tach doesn't move while cranking either.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 10-26-2009 at 06:50 AM.. |
Architect / Car Guy
So it dosent move?
Looking Forward to getting my First "car" Porsche 951 |
The next time the car starts take it to Auto Zone and they will check the alternator and battery for free. I went through three new batteries in a 6 month period one year. Just because the battery is fairly new doesn't mean it can't short out inside and your recharging it all the time.
Cheers, Larry |
Professional Bull5hiter
What I think is happening is you have a voltage drop problem. A wire somewhere (maybe more than one wire) has a resistive connection and the DME is not getting enough volts to run correctly or it's not sending correct signals out. This maybe on your supply rail to the DME, or it could be a sensor, or it could be the wire to the coil, or it could be a ground connection. Sorry, being intermittent, it'll take some time to find it. Get a schematic and a meter and check off each electrical connection methodically. In some cases (depends upon the signal involved) a few ohms resistance may be all that the problem is. Cheers
Jeff 83 944 Guards Red 23 718 GT Silver |
1984 porsche 944 na
Had the same problem I could start car if I hooked up a battery charger had exact same symptoms. It turned out to be an open in the harness that goes to the starter. A high open can be jumped with more juice ie: the battery charger. I hooked up a voltmeter to my starter and waited for a no start again when I did I was only getting 7v to the solenoid. To save time fixing it right at first I just installed a start switch in the car to supply 12v to solenoid when I needed it worked like a charm..
1984 Red NA/Sold 1984 Gray NA/Sold 1986 Red NA 1986 Gray NA |
It is fixed and reliable again ! I gave it a couple days just to be sure. Replacing speed and reference sensors did the trick. She fires up immediately and runs strong. I did break the sensor bracket to get the speed sensor out, but I am sure it was a good thing as it allowed me to reset the sensor gap. I took the advice and used a bad sensor and glued a washer (of appropriate thickness) to it as a tool for future use. I bought the BMW sensor (sorry, but with 3 porsche mouths to feed...all demanding my paycheck...I had to cut costs somewhere).
Many thanks to all who helped point me in the right direction !!
Matt '87 924S |
so once agAIN, you find yourself at "wits beginning" instead of wits end"!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
I would agree with the "at wits beginning" , but it is a 944...so in actuality, I'm just waiting for the next issue to arise.
Matt '87 924S |
