-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Where does your car idle at? (http://forums.pelicanparts.com/showthread.php?t=513618)
thekidd 11-29-2009 01:15 AM
Just was wondering what did they idle when new and what does you car idle at? Mine idles at just below 1.2k with a late model DME and AFM, it use to idle at 950RPMs with the stock computer and AFM. I'll have to screw with the set screw probally.
phil823 11-29-2009 04:33 AM
mine used to idle at 950. i put in a custom aftermarket chip, it raised it to 1k. so i set it back down.
i set it to 950 when its warm, with lights on (light lower RPM by about 25 or so)
my manual says 900 +/- 50 i believe
1.2k would be brutal! i tought 1k was loud and annoying!
choinga 11-29-2009 07:57 AM
factory is 840 +/- 40 RPM. I'm running a Vitesse MAF/chips and idle in that range most of the time. Occasionally, the car will idle closer to 950ish when warm but I haven't been able to figure out what the situation is that causes that - it's rare.
Make sure that you jumper the DME test port to pull the ISV out of the loop before turning the screw - you shouldn't just crank the screw once your car is warm...you'll have problems then.
Dean924s 11-29-2009 07:58 AM
According to the stock tack it is at 1K. According to the VDO tack I have wired to the Ford EDIS ignition I am running it is a 900.
exitwound 11-29-2009 08:02 AM
Mine idles at 1050 or so. I have it set artificially high because when cold, it idles far too low, ~500. I have to keep the throttle on for a minute or so until it warms. I've checked the ISV and it operates fine. However, it still idles too low and wants to stall out when the air is colder than 40F.
ernie9944 11-29-2009 08:36 AM
Mine--- 968 chips with OE air intake & K&N---- between 925&950 warm. 944 with OE (AFS) & k&N cone filter was idling 900 to 950 warm.
jcommin 11-29-2009 09:13 AM
Just under 1000. I have a stock n/a.
OnTheRun2 11-29-2009 09:19 AM
Mine idles in my driveway, but other than that it's mostly "RED LINE" LOL
Icey1174 11-29-2009 01:44 PM
900 - 950, somewhere in that range.
thekidd 11-29-2009 02:34 PM
got mine where the tip of the needle is at the lower edge of 1K. Id say mine is idling at 999RPMs, but cant seem to get it to 950 where it was before. I staill have to do some maintenance- oil change, coolant drained, T-Belt and everything else in that bag. Thanks guys
phil823 11-30-2009 01:46 AM
mmm i just warmed mine up, and turned the little idle screw ever so slightly while the engine was running. i havent had any issues........wierd
cvriv.charles 11-30-2009 02:04 AM
Mine is at about 1100 or so because thats the only way my car will idle. ISV is bad. Plus im sure I have a few other things going on under the hood. I have yet to fix this stuff:(
flash968 11-30-2009 08:08 AM
my cars idle in my driveway, at stop lights, and sometimes at curbsides - but seriously
my 6 spd 968 idles at 850 (the book says 840+/- 40)
my tip 968 idles at about 900 (the book says 880+/- 40)
a 944 in the US is supposed to be 900 +/- 50
a high idle can be a sign of a vacuum leak - those little hoses can come undone pretty easily
mikepellegrini 11-30-2009 08:13 AM
My 83 NA idles right around 1K.
cvriv.charles 11-30-2009 10:42 AM
I turned my idle up to smooth out the idle and to keep the car from stalling. Along with the isv I might have a vac leak somewhere which is messing up my idle.
thekidd 11-30-2009 01:28 PM
I did replace some of my vacumme lines while the car was down for a few months. I will have to do a look-over and see what hoses are loose, or if I am missing any. People say to spray something into the intake to check where a vac leak is. I forget what exactly it is, I wanna say starting fluid? They say be very carefull, so thats probally it. I dont like my car idiling at 1K or so.
Ctan 11-30-2009 02:07 PM
1.2k cold/1k warm. I tried lowering it to 1k/850 but it hunts when it's cold and staggers when hot.
I must have a few vac leaks... that and the PO swapped the 84 engine out for an 88 and may have missed a few things. I'm finding them as I go lol.
exitwound 11-30-2009 03:40 PM
Do NOT take my word for it, but I think it's Carbeurator Cleaner. Extremely flammable stuff though.
thekidd 11-30-2009 03:52 PM
You may be right, I do know that they said be carefull not to get to close. Ill do a quick search and edit this post.
flash968 11-30-2009 04:11 PM
carb cleaner will work, and is what i use for this, but be careful not to get it on paint - the idle will stumble when you hit the leak
starter fluid will work, but is HIGHLY flammable - this is dangerous and is NOT recommended - the idle will race when you hit the leak
