How long are torsion bars?
Are all 944 NA torsion bars the same length?
I have read they are 26 -9/16" and that some VW parts will match. Would these work on my 84? Not sure if the splines are the same. http://www2.cip1.com/ProductDetails.asp?ProductCode=C12%2D6569%2D28&CartID=1
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy My Website: http://www.TrackPics4Less.com |
All 944 torsion bars are the same length, and differ in diameter depending on year and option (M030, etc.).
The key is to get the correct splines on them. They are compatible with some VW bars from certain year baja bugs I believe- the 1200 series. I just do not know weather or not they have the same splines. I researched this a while back looking for big track car torsion bars. I found a page with info on this but I need to re-find it. I'll post back when I find something..
M |
Toofah King Bad
Those will work. . .guess where Porsche dipped their fingers to get 924 t-bars? Specs never changed, thru 968.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thanks. I'll call them first though. Is there a socket diameter or spline count I should ask for?
Toofah King Bad
All the VW "IRS" t-bars will work, as long as they are the correct length. Splines, etc, are all the same, 76 924 thru 95 968.
Perfect. Thanks!
update to save someone else a headache later....
The t-bars from CIP1 aren't an exact match. The difference is the length of the splines on the outside end of the bars. There are about 1/2 inch more splines on these bars. Why is that a problem? It's not, unless your doing the hole-saw-in-the-rocker-panels method and removing the end of the t-bar cover to just insert the new bars from the outside. There's no way to seat the inside splines first because the outside start in the grooves first. My shortcut and money savings has taken twice as long and cost more than the correct bars!
so how much spline is there in total? how much is the correct tbar supposed to have?
Why not try Sway-away bars? I picked up a set of 1228s and 1226s on e-bay for $140 a while back. They area direct fit.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Toofah King Bad
Wow, never saw that one coming. At least you get to pull the suspension to install proper bushings!
