Will early 944 belly pan fit my 85.5?
I have a line on an early 944 belly pan, and need to know if it will fit my 85.5. Anybody?
Proprietoristicly Refined
PET says no but you could double check.
Porsche Classic Original Parts Catalogue - Classic Catalogues - Porsche Classic - Dr. Ing. h.c. F. Porsche AG
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Az 944 Spec Director
I suspect it will,
You may need to make some mods to pull it off. (Ie drill and extra hole or two) The pan needs to mount to the lower radiator support in front and to the cross member in the rear. The two side plates can be removed. I cut them off years ago to make room for brake cooling hoses.
Joe P. 88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White Arizona Region 944Spec Director Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09 4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up) |
I had one on my late 944 Spec car. The rear holes line right up, and I was able to make the front work. The side wings have no where to hook up, but are not needed, and can be removed, as Joe mentioned.
Eric Kuhns NASA Great Lakes Super Touring Series Director 2007 & 2008 944 Spec National Champion 2015 NASA Eastern Champs 2nd place in ST2 "Franken44" |
