A/C Leak Question
It's about time that I get started on getting the A/C working again on my 944. Apparently the system has a leak in it. I found a copy of a test done at Midas some time ago and all it says is: "Major Leak W/AC - Compressor + O-Rings." I know that the front seal on the compressor is bad and plan on replacing the whole compressor but I am unsure of what O-Rings need to be replaced. Naturally I am going to replace the ones on the compressor when I replace it and the O-Rings on the drier as well.
In anyone's experience, are there any other seals that commonly go bad that I should replace before I go to have It tested and charged? |
Keeping it cool
Take a black light to the AC system and see if you can find where the PM spotted the leak. Systems are usually tested with a phosphorescent dye in the Fluid. where it leaks out there will be some dye and you can spot it with a black light. If it was tested a while ago then the dye may have rubbed off and you have to add it and Pressurize the system again. Another way to test is for a technician to vac it out and see if it holds vacuum. However, that doesn't tell you where it leaks, just if it does or doesn't. Ask the technician to have it hold vac for a while as this cleans out the system by evaporating water.
Hopefully your system has not been open to the air as that causes problems. I would the AC pump seals and the condenser seals as they are reasonably easy to get to. Have a technician vac out the system before hand(if there is anything in it) to not release freon. then have the tech test it. If it holds vac....fill her up and cross your fingers. |
You have to replace the receiver/dryer ----and the "O" rings with a new compressor. TIP-unplug and install this last so as not to foul the internal dryer material. You should flush ALL the hoses, evaporator and condensor. You need new seals. You should not flush the expansion valve---------unless you have too AutoZone has a small kit for $5.99 which should be enough "O" rings. I used the Pelican kit with all the conversion valves and "O" rings needed Pelican Parts - Product Information: 55-9807-901-M325 All this being said, You could possibly get by with just a new receiver/dryer and the seals from AutoZone with your new compressor. This is what I would try first. Important Use the correct AC oil for the freon you plan to use. R12 oil is not the same for R134a. Even though products like Freeze12, R22, IceBallCold freon work, I do not recommend. They are flamable and once used, many AC shops will not work on your car. It may ruin or contaminate the equipment. Search for member mattdavis11. He has a lot OJT knowledge. GL John_AZ |
texasblake did a complete conversion and posted it on his website. There may be useful information when you put in the rebuilt compressor and dryer. A/C Retrofit - Porsche 951 - www.texasblake.com I would also consider flushing out the condenser if you do no other flushing. The old PAG oil settles at the bottom of the condenser. This can cause a restriction in the freon flow and poor cooling. It is just 2 more "O" rings (AutoZone kit). This will remove any dirt and sludge (compressor chunks) built up after 23+ years of servicing Always put AC oil on the "O" rings to avoid a pinched "O" ring when installing. The rebuilt compressor will have Esther oil inside. The receiver/dryer should take and additional ounce. Check to see if the compressor has enough oil installed for both. If you do flush the condenser, you should also put 1 ounce of Esther oil in. If you open up the system again in the future, replace the receiver dryer again. Pelican sells for $11. Pelican Parts - Product Information: 944-573-943-00-M253 GL John_Az |
I assume that the 87 944 still has the nippondenso 6E171 compressor, if so, find someone to rebuild it or do it yourself. It's just a few seals. I could reseal the compressor if you'd like, just mail it to me. Let me know.
The advice is solid on looking for other leaks. Black, oily residue near any connection or fitting is also a dead give away for a leak. Remember when changing from R12 to 134a you will only charge to 80% of the factory recommendation. Another note of caution, 944 online says that it's ready to be bolted on, I'm not so sure about that. George is a great guy, very knowledgeable, but he has no earthly idea how much oil has disappeared from your system. Fast leaks obviously lose more oil than slow ones. I almost always start fresh, however I didn't on my car because I can guestimate pretty good. At the very least (if you don't flush the system) measure what is in your compressor and drier and put that amount back into the new to you compressor, and never take someone's word that there is oil in a compressor, always check. I've bought new ones that read "contains 5.3oz of pag 46", but there was not a drop other than assembly oil. Do it right, do it one time, enjoy it for several more years. Check the service port fittings when you get done adapting, new ones sometimes leaks too. |
John,
Did you end up charging your system with R-12 or R-134a using the Nippondenso? I want to be able to charge it with R-134a because it seems easier from a maintenance and cost perspective. It looks like Texasblake is using the Sanden compressor which was designed for R134a but that compressor is twice as much. Quote:
I used R134a (WalMart $6.79 a can) and PAG 46 oil. 2nd season has started and works fine at 85 degrees so far.
Repeating what mattdavis11 mentioned, I used 24 ounces--2 12oz cans R134a in my system. Not the R12 capacity. I replaced every seal and even the expansion valve seals. But my underdash blower, evaporator and expansion valve unit comes out in 45 minutes. You are not so lucky. GL John_AZ |
All compressors are designed to do the same thing, it's the oil and freon that are different, nothing else. I didn't ever flush my lines, I just resealed the compressor and put in pag oil and charged with 134. I know I have two different kinds of oil in the system but it's worked great for 7 years now. Reseal your compressor for $10-15 bucks (at the most) and save a ton. It's not very hard, getting the clutch off the nose of the compressor is the hardest part. Otherwise send it to me, I'll do it.
I have not replaced but a few orings, one at the condenser, and ones at the compressor. That's what, 3 orings? If they don't leak, don't open the system where you don't need to. |
Belt routing
I have been thinking about possibly rebuilding the compressor myself and saving a couple of bucks. Is there a way I can route the belt so I can still drive the car while the compressor is out?
AC compressor delete
LEyes: as the compressor is used as a tensioner, you will need a bracket or to shoehorn on a smaller belt as a temporary measure. Check this thread out.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/439030-c-delete-belt.html If that doesn't give you enough info, Clarks mentions the AC delete somewhere (I think) Or, you can do a search in this forum for compressor, AC, Delete, Belt, etc... which should yield something useful. |
I have just found that the leak on my 951 was emanating from the high pressure port. Tightening the core with a valve core tool eliminated the leak.
Wild man rocks!
Congratulations Wild Man! two smileys for you! :):)
Next time you have the system open, replace the valve. |
Thanks for humoring me! Although it is still early yet, I think you just made my day. I haven't opened the system up to the atmosphere yet. But if I do, I'll change the core, and the LP side one also, if it's not too much of a hassle. Maybe I should have mentioned this in the 1st post, but the HP port took at least 2 addtional turns, from where it originally was. This is how I detected the problem: I saw some thick, almost clear liquid pooling on the left strut mount (tower?) that I 1st thought was brake fluid. Upon further investigation, I had determined that it was A/C oil charge. With my ear close to it, I then loosened the plastic cap on the valve, and heard a "ssst" sound emanating from it.
dilligence
Yea, I check the valves as sometimes the AC technicians don' t install them fully. I also check the caps all the time to make sure they don't walk away. A spot of paint on the fittings assures no one will accidentally loosen something.
Hey guys, thanks for all the helpful info so far. I really appreciate it. I've been busy so I'm still in the process of deciding if I'm going to rebuild the compressor myself, or have someone else do it.
Also, one thing I am concerned about leaking is the condenser. Since the system is completely empty, is there a way that i can disconnect it, plug one side, and pull a vacuum on it to see if it holds a vacuum? |
A/C sucks
The vac test is usually performed by an AC technician. You see how long it holds vac and it also evaporates water in the system. Usually you test the whole system by pulling a vac on the low side nipple. ( he he, I said nipple!, he he) If you were to disconnect the compressor, the system is no longer a loop, and you would have to plug the compressor fittings somehow...eh..how about with a working compressor?
There have been a few mentions on here about opening the system to the atmosphere. Since the A/C system is completely empty, I'm planning on taking out the condenser so I can straighten out a few body work issues. Should I be concerned about leaving the system open for any extended period of time? I am planning on replacing the drier when it comes time to recharge the system anyway, which I am assuming is the part you don't want left open to the atmosphere.
Don't
Do not leave a system open to the atmosphere. Moisture gets in and ruins the components. If you have to take out a component seal the rest of the system.
There will be no repercussions if you flush lines right away and cap them unless you let it sit. An acid is made when you expose a/c parts that have seen R134a, pag 46 and oxygen\humidity. If you let it sit, you expose yourself to corrosive damage. I didn't check to see if you have converted to 134.
If you understand the temperature at which moisture boils in a vacuum, the drier could still be good to go unless the compressor disintegrated and shot metal slivers down the line. You shouldn't flush a drier, and they are cheap, but I haven't changed mine. Flushing always consists of moving solvent (I like denatured alcohol) the opposite direction of the travel of the oil and refrigerant. Think thumb releases in a timely fashion, when the pressure builds, release away from your eyes and face. Wear protective eye wear. We are lucky to not have parallel flow, or micro tube condensers. |
I was able to pull the condenser the other day because I had to straighten out a few things, including one of the brackets that holds the condenser in place, and the condenser is pretty bent but I can't see any evidence of cracks or leaks on it. Are these things pretty resilient to leaks from bending? I've attached a picture below.
http://lh5.ggpht.com/_jBYE7Exppv8/S-...er%20sized.jpg Quote:
Thanks! |
I'll add a couple of thoughts before Matt replies.
Matt is an AC professional. With his knowledge and tools, what would take him 30 minutes will take you a weekend. There is a special tool to remove the clutch pully as Matt mentioned. If you are in the rust belt it may never come off. Back to the Q. You can get the seals and if you want to do a brilliant job, replace the races at Griffiths ---order the correct kit --example: Porsche Nippondenso Compressor 10P15 Seal Kit compressor seals, nippondenso, denso, seal kits, air conditioning compressor seals, 10p15c seal kits, 10p15e seal kits, 924s seals, 944 seals, 911 seals, 930 seals, 911 compressor seal kits, 930 compresso I am sure Matt can do better. GL John_AZ |
I would have the condenser pressure tested. This can be done by yourself if you have a vat, compressed air, and a way to plug one side where one of the fitting attaches, the other attachment needs to have a special plate that you can use to pressurize the condenser. I doubt you would have one, I don't at the moment either.
I buy all my seals from Santech out of Fort Worth. Automotive Air Conditioning Components : Santech Industries, Inc. You are looking for a case seal and shaft seal kit for a Nippondenso 10P 15E compressor. If you can't buy from them without an account and don't want to set one up, let me know, I can get you what you need. I actually have one shaft seal kit at home. The part number is KO 20 something, but it's probably been superseded by a new one. They have all the tools you need as well. Santech is pretty much the king of ac sealing and rebuilding products. Dallas/Ft Worth is the AC capitol of the world, if you can't find what you need there, you're searching for a dusty box buried in a warehouse in Germany. I can also get you a condenser, it is special order for me at $140 to your door. They are semi pliable, but be careful. If you skip the aforementioned pressure test you may get lucky in finding that the system holds a vacuum after you seal everything up. Let me know if I can help in any way. |
Thanks John_AZ, it takes me a good while too as I enjoy the projects, but moreso the beer that accompanies said projects. I havea friends Volvo S70 getting a full ac job (minus the evaporator and condenser) that I started at 2pm yesterday, I'll finish it sometime today. I got lucky with not having to replace the condenser as very little metal was on the orifice tube and it is a microtube condenser that can not be flushed. We can flush ours, but our compressors aren't prone to grenading, so we really don't have to worry about it.
Also, I think I've decided to just go and buy a rebuilt compressor and make it easy on myself. I found a seller who will sell me a rebuilt compressor for $200 and is offering to buy back the core as well. He asked me how much I want for the core, what do you guys think a fair price would be? |
No idea, it used to be wash on the core charge if they can be rebuilt, which most can with our compressors. Demand for cores has gone up. I'd hold on to it. For $5-10 in parts you have a spare.
Thanks again for all the help. I have my new compressor and a new drier ready and I just need to flush the lines before I can go to get it charged. I'm dreading this part because it seems like the biggest pain. How do I go about flushing the lines with denatured alcohol? Might be a dumb question but, do I need any special equipment or is it as easy as pouring it down the hose? |
Nope, no different. I have a flush bottle that hooks up to compressed air. It has a nozzle with a rubber tip. That's all I use. You can pour it down the line or spray it down the line, your choice. It's faster with a flush bottle. Every parts store has them.
Update
I was able to flush the condenser and some of the easy to get to lines in the front of the car. At that point, I decided that was enough and installed my new compressor and drier and decided to bring it in to be charged. What they found was that the condenser, although bent, still held pressure BUT they discovered a new leak in the area of the evaporator! Ugh...
With that said, Is there any way possible to replace the evaporator without removing the WHOLE Heating-A/C unit? Quote:
Before you remove the entire dash to check or replace the evaporator.
I would remove the heater blower motor in the rear center top of the engine compartment You will have access to the expansion valve that sits next to the evaporator. Your problem may only be the seals on the expansion valve. If you are very lucky. With the blower motor out you can get the seals replaced and have the tech use an electronic sniffer to see if the evaporator is bad when he does a leak down and refill. OR, you could just begin to remove the entire dash on the late 944... http://tech.rennlist.com/924_944/porsche944dashremovalinstallation.pdf The early 944s and the 924Ss---the entire blower, evaporator, expansion valve and housing comes out from under the glove box in about 45 minutes. This is not the case with the late 944s. mattdavis11 may have another solution. GL John |
With out knowing what they did, I would first suspect the compressor. Who knows, they may have shot it full of nitrogen and tested for leaks and when they saw none with soap/water mixture in spray bottle, they said evaporator. There have been times where a shaft seal leaks slightly because the oring didn't get seated properly, hadn't been oiled prior to installation, or a groove on the shaft didn't get polished out, but they seal up nicely when rotated and oil/refrigerant circulate. If you bought a brand new compressor (probably not) the shaft seal could be rotten. That's a hard to find slow leak on the compressor because of the clutch.
What I'm guessing you could be up against, is a shop that didn't get to sell you any parts and could be trying to convince you something else may be wrong. Has the compressor cycled? That meaning, refrigerant has been introduced, the system cooled, shut down and engaged again when it should? I have no idea what they did. If they put dye in the system, you should be able to see it with the naked eye, but a pair of yellow tinted protective goggles and a black light helps. |
In response to Matt: I'm not sure if they injected a dye or not. I suppose I can try to find out exactly how they diagnosed the leak in the evaporator first to make sure they didn't just assume it was there. Also, as far as I know the compressor hasn't been cycled. |
i have a rebuilt compressor i'd like to install, but how do you unplug the electrical connection from the compressor, it seems to have a metal clip that goes around the compressor with metal ears that are going into the plug.
If you are not talking about the main compressor 12V single wire-----I guess you are referring to the connection at the clutch coil.
It does not come off. Or I am confused... John |
there is only 1 plug i can see, it's at the front next to the pulley.
if it does not come off, how do you remove the compressor? |
That is the Clutch Coil wire. The coil activates the clutch and the compressor spins.
The compressor, coil and clutch usually are sold as a unit. Take the compressor-with the pully attached out. If you buy a compressor without a clutch/pully attached you take it to a shop with special tools to remove it. OH, it can be done at home if not rusted on but a shop will take a couple of minutes. Try to get a rebuilt, guaranteed used compressor with a clutch installed. GL John |
my question is how do you unplug the wire so i can take the compressor out.
do i have to just cut it, or is there a plug connection somewhere upstream i'm not seeing. |
The main wire should be a male and female spade connection about 18"-24" from the coil/pully along the frame held by tie wraps.
thanks John, i'll trace the wire back until i find it
There's one sure fire way to find it, remove the mounting bolts, remove the ac lines from the top of the compressor and it'll be the the wire that won't let you haul it out from under the car.
| All times are GMT -8. The time now is 10:40 PM. |
