-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Removing fuel injector cap without breaking (http://forums.pelicanparts.com/showthread.php?t=527509)
krookideyez 02-21-2010 08:51 AM
So I found that a fuel injector was spraying due to a tear in an injector o-ring. I need to replace one injector o-ring. I have a few o-rings lying around.
The only problem is removing the injector cap without cracking or breaking it. I've removed the old ones before and I broke each one while doing so. Mind you I was not being careful since I was replacing them anyway.
Has anyone successfully removed a cap without breaking it?
thekidd 02-21-2010 09:43 AM
i got replacement o-rings and hats at pep boys. $6 or so for 4 injector
krookideyez 02-21-2010 10:04 AM
$6? wow that's a good deal...much better than $28 plus shipping on rennbay that I paid! I guess I'll go for these if I break the cap. Do you have any info on the caps and o-rings for the 944? part number? internet link? Thanks kidd
krookideyez 02-21-2010 10:13 AM
I wonder if applying a small amount of heat (like from a blow dryer on low setting) might allow the cap to relax a little so I can persuade it off gently. I'm assuming this could warp the cap but it's worth a shot right?
Could this heat hurt the injector? I mean, it does sit right above the engine so it must undergo some heat right?
John_AZ 02-21-2010 10:35 AM
I think............the quoted $6 is per injector. You paid $28 for a set of 4 injector kits.
I went to a VW parts house (BAP) and picked up a set for 1 injector for $5.
thekidd 02-21-2010 10:44 AM
Here is the link. There are a few injector kits there that dont have prices, but they may be cheaper. I got the $1.99 ones (4 all together)
Pep Boys
krookideyez 02-21-2010 11:37 AM
just got it off without breaking it! I cut the o-ring off with an exacto knife, then took a pair of needle nose and pulled up on the plastic washer and it popped off with a good amount of force.
Time to lube the hell out of them and get that back into the car!
