-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   What's wrong with this picture? (http://forums.pelicanparts.com/showthread.php?t=528838)
cwiert 03-01-2010 09:31 AM
Hi, I've got a question for the group. I'm looking underneath trying to find where a slow oil leak is coming from and I noticed this. I'm not sure what it is, but the rubber bushing thingy looks pretty worn. The same bushing thingy on the driver's side looks much better (pic of that one too). The questions:
- what is this?
- what does it do?
- is it hard to replace?
- how crucial is it to do it now (what could or will happen if I don't fix it now)?
Thanks in advance.
-John
http://forums.pelicanparts.com/uploa...1267464549.jpg
http://forums.pelicanparts.com/uploa...1267464585.jpg
Techno Duck 03-01-2010 09:48 AM
Sway bar bushings, easy to replace and very common due to the power steering leaks from these cars. Also when you change the oil and take the filter off it usually dumps oil right onto that spot.
Measure the swaybar diameter and order the bushings you need.
flash968 03-01-2010 10:17 AM
the bushing is oil soaked - likely to be power steering - oil (or power steering fluid) destroys rubber bushing material
fix the leak - no point in changing the bushing until that is done
race2fast 03-01-2010 10:19 AM
Time for a new car... :)
cwiert 03-01-2010 10:25 AM
sweet. you givin' them away? :)
KrazyKarl 03-01-2010 10:29 AM
Had the exact same issue on my car, as flash968 said you'll want to fix the leak first. It's not all that hard to replace, the bar can be removed by loosening the two brackets going to the frame and the two end links running through the control arms. Cut the old bushings off with a knife and slide the new ones on with some soapy water. It's not a critical issue, but it will affect performance when cornering as the sway bar may bind.
cwiert 03-01-2010 10:30 AM
its soaked in a combination of ATF fluid (PS oil), and engine oil. But finding the source isn't easy. I think the ATF fluid may be coming from the PS reservoir itself. I tried to get in there and clean everything as much as possible so i can try to find where the leak(s) are coming from.
ernie9944 03-01-2010 10:30 AM
Don't forget to clean your steering boots & degrease everything that is rubber while in there then apply a Vinyl & rubber conditioner on them I found Meguiar's the best for that kind of stuff it does last a long time.:)
krystar 03-01-2010 10:37 AM
also looks like yer sway bar is shifted over the driver side..try to get that back in the center
Techno Duck 03-01-2010 04:07 PM
The leak from the reservoir which soaks the bushing is 99% of the time the two hoses coming out the bottom. Replacing the hose clamps (or just tightening the ones on there if they are not too stretched out) usually works to stop any leaks from there.
cwiert 03-01-2010 04:25 PM
Thanks. I'll do that. The PS leak appears to be coming from where you just mentioned. I cleaned the hoses and that little ledge right beneath the reservoir the other day, and today i just noticed some fluid on the hoses and that ledge again. So it can only be coming from the hoses that connect to the reservoir. I'll try and tighten them up and see if that fixes that. Thanks for your help.
