Hi all,have engine in car and running ,started easily after priming fuel system
.Have exhaust to modify as centre box is a cat converter which I don't need and is probably blocked anyway after 21 years. All appears ok @ this stage but my tacho won't work ? does this work of the coil or the speed sensor ? ,hope someone has a quick answer ? ,cheers
Just did a transplant myself...1989 2.7 into a 1986 chassis...tach had to be connected from the DME...green/yellow wire if i recall...
brant giere 2005 996 cup 1991 964 euro cup (Larbre #28- race 1987 carrera 3.2-street/de car 1962 Austin Healey 3000 |
i put an 88 motor in an 84 chassis and the same problem, tach doesn't work. is what you describe as a fix different from the normal connection to an 84 chassis wiring harness?
'83 944-Spec(SOLD) '84 944-Spec(SOLD) '90 944 S2(SOLD) '89 944 Turbo(SOLD) '85.5 944(SOLD) |
Thanks ,yes I traced back with tester and found green/yellow wire,this was on or should I say attached to main loom with its own "'mystery"
8 pin plug.Haven't wired up as I have other probs .
I did this swap as well a 85.5 2.5L into an 84, I even cut the same hole as you did. Ran into the same problems. Thinking back on it; in the case of the S1 body cars going Megasquirt and making a new wiring harness is a better option than cutting holes. But for that matter almost as easy is getting an OBDII system out of any german car and refitting it to your car is a much better plan. Then have some one burn a chip and tweek it from there. For instance my 92 Jetta has a 98 2.0L runing OBDII and it just kicks ass. DME is So '80's IMO.
Revis Rose '84 944 NSRC |
