Custom User Title
Dave L's Avatar
What is this tool for
Here is a little test. 21mm socket held with vice grips, Inside is a short 1/4 extension with a 13mm socket.
Anyone know??
Old 06-13-2008, 07:41 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Top strut nut..... Made one myself, now I use an O2 sensor tool. ;-)
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 06-13-2008, 07:55 PM
Custom User Title
Dave L's Avatar
yes I suppose (assuming the sizes are right) I could use it for that. The tool was used for something else.
Old 06-13-2008, 08:18 PM
That's a great idea. I just use an impact wrench these days but there are many times out at the wrecking yard and I'm collecting a set of Koni's of Bilsteins for eBay. There's been a few times I had to give up on my gound treasure.
Old 06-13-2008, 08:32 PM
Will work for parts
944 boy's Avatar
There is also the sunroof clutch tension, but I forgot what the socket sizes were. I want to say there was one other time I used that method but I can't think of it.
Old 06-13-2008, 10:02 PM
Custom User Title
Dave L's Avatar
Yes, Sunroof clutch adjustment. I did a search and found a post from 2003 mentioning this method. Other methods included grinding down wrenches to make them thinner but this seemed like an easy solution. And best yet it works.
Old 06-14-2008, 05:38 AM
fast924S's Avatar
Send a message via AIM to fast924S
I think I see a good idea for another ARNNNWORX tool
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-14-2008, 08:33 AM
Will work for parts
944 boy's Avatar
Yeah, 2003 is about the time I fixed mine and it worked flawlessly up until a month ago when I tore the whole thing out of the car. I even used a microtork torque wrench to properly set the tension. Now I miss the power sunroof :-(
Old 06-14-2008, 09:52 AM
gtroth's Avatar
Yeah, I ground down a wrench to thin it down. If I had to do all over again I would have bought a 13mm bicycle wrench. Not sure how your tool works - both of my clutch nuts were 13mm.
1995 993C4 guards red
1988 944S alpine white
Old 06-15-2008, 03:40 PM
Custom User Title
Dave L's Avatar
the 21mm held the large nut while the 13mm loosened off the nut that sets the tension. By turning just the 13 mm alone it would spin the motor and the sunroof would raise or lower. I had to stop the 21mm from turning. The tool holds the 21mm nut while the socket inside was free to turn and loosen the nut.
So far so good, I adjusted the tension without a torque wrench (neither of mine went that low) but set it loose so it would just spin then slowly tightened it until the clutch would no longer slip.
Old 06-15-2008, 04:50 PM
Morrie's Avatar
I am definately missing something, even after reading on Clarks and the factory manual. I have a torque wrench that goes that low. How do you set the torque. It says to use the 21mm to check with the lift partially up, but obviously when I turn the nut the cable drive moves. Mine is definately too tight as it took out the gears. Can someone help me with a little more explanation?
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 03-26-2009, 08:16 AM
Just thinking out loud
mattdavis11's Avatar
Sunroof adjustment??? You just turn the latches 90 degrees and push up.
91 FJ80
84 Ram Charger (now gone)
Old 03-26-2009, 03:37 PM
nightheart's Avatar
isn't it 180 degrees to prop the roof up? no adjustment required or special tools.
This was probably posted from my phone, so please excuse any typos.
Old 03-26-2009, 04:43 PM
gtroth's Avatar
What I do is loosen it until it slips and can't raise the roof and then tighten it bit by bit until it can (I don't use torque wrench for this).
Old 03-26-2009, 07:50 PM
Morrie's Avatar
That seems like good sense to me gtroth. Makes more sense than what I have read up to now!
Old 03-26-2009, 08:13 PM
