All Spooled Up
Is my alternator going bad?
I have to put a charger on the battery every couple of weeks or so, because it seems to slowly get run down, until it will no longer start. In trying to figure out what the problem is, I took some voltage measurements. Here is what I got, after taking it off of the charger, and starting the car:
13.7 volts, with no accessories turned on. it did not go up at all when I gave it more revs. 13.4 volts, with lights (high beams), blower motor, and rear defogger on. Also did not go up when I gave it some revs. I don't think it should ever go below 13.8, even when loaded down. So I'm thinking that the alternator is dying (alternator light is not glowing, even slightly), but could it be just the regulator that needs to be replaced?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
id say its already gone, once you start your car the voltage should jump to about 14.4~6 due to the alternators charge coming in. take it off and have autozone/pepboys test it for you its free and rather simple.
1983 944 Guards Red (87' Implant Complete) |
Under the car
I think these cars are a little too old style to be expecting 14.5 out of. It seems like his 13.7 number is close to right but maybe the regulator or some of the windings are going bad and it can't keep up under high load. What is the voltage when the car is turned off. Maybe you have a bad battery and the alternator can't get it to go above the 13.6.
it probably needs a vr, brushes are worn.
pepboys, checker, napa can check it on the car.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
Parrothead member
I agree with MattB 13.7 does not sound bad at all. it is still charging the battery. I would have the battery tested. That sounds like your problem.
Also, did you check to see if you have a drain on the battery?
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." Last edited by VINMAN; 04-02-2010 at 06:39 AM.. |
All Spooled Up
Cars & Coffee Killer
Yes, the alternator is probably bad. You should be at 14 volts, maybe a little less when blasting the stereo with the headlights on. I put an aftermarket voltage regulator on my old 951 and set it at 14.5 volts when I had it rebuilt. This solved a lot of quirky electrical problems with the car.
You probably also want to replace the main grounds along with a new/rebuilt alternator. I'd also check for voltage leaks. Do a search for posts by Iceshark. He had good procedures for doing this. Also, just because a battery reads 12.5 volts doesn't mean it isn't bad. A battery can still produce good voltage without delivering enough amps. The simple way to test this is to buy a device that tests the density of the fluid in the battery. You can pick one up at any auto parts store for under $10. Assuming you do not have a maintenance-free battery (this won't work if you do), you just pop the cover on the cells and suck the fluid up into the testor. A little dial with tell you if the fluid is good (can deliver enough current) or not.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
a high rate discharge test is the best.
All Spooled Up
When I stated that the battery showed 12.5V with the engine off, I actually meant that in a "good" way. It probably would read a quarter volt or so higher if it is given a full charge and then left to stabilize for 2 hours. It is a NAPA professional line (The Legend) 75 month battery with CA rating of 815, and a CCA rating of 660. Although at first glance, it does appear to be the "unmaintainable" variety, it really is not. The caps are removed as 1 rectangular piece of plastic covering half the battery. And I do maintain it well, keeping it (and the terminals) clean, and always making sure the electrolyte levels are up to the split rings. Specific gravity testing comes up good on all cells.
I agree that "a high rate discharge test is the best" way to test a battery. And there is no more convenient of a way of conducting such a test, as cranking over the engine. It is not too often that VR's start to fall short on their regulating capabilities, so most likely some turns in the alternator coils are starting to short out. But I still see where there is a slight possibility that it could be the VR. That is because the brushes that feed the VR juice to the alternator's field winding are attached to the the VR, itself. And if they are worn down to the point where they are starting to loose connection with the alternator's commutator rings, I think that could possibly be making it show that symptom's that I am seeing. In summary, the question I was asking in this thread was, what are the chances that is the problem, and not the alternator itself?
Toofah King Bad
I think 13.7 is fine. I also think that if you disconnected each ground strap, brushed their ends and mouting points well with a wire brush, and reinstalled them with conductive grease, you might get a couple more tenths.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
he's getting 13.4 with lights/blower/rear defogger and that's too low.
All Spooled Up
If anti seize compound qualifies, then it has already been done (except for the bellhousing one). I really don't think that you should never see less than 14.
Redline Racer
Maybe the alternator wire to the battery or the starter to battery wire is internally corroding and needs to be replaced. Could be bad battery clamps, or bad connections at the auxilary ring terminals at the battery positive clamp, which supply juice to pretty much everything on the car. IIRC I got around 13.8v with a brand "new" rebuilt alternator and it still did dip a little under load (mostly the radiator cooling fans). The idle does get a little rough when the cooling fans come on, and a new battery didn't do anything for that, so I may need to look into a wiring upgrade. (hmmm...another epic project materializing as we speak
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
I've got a similar issue with my '86 944. I install a new battery and she runs fine, with perhaps a slight but noticeable deterioration in starter cranking time, for about 90 days. Then, one morning, nothing. Not even a click when I turn the key. I remove the battery, and find it open. Complete failure. I replace the battery and that resets the issue - in 90 days, I'll be doing it again, perhaps a little sooner if I don't drive her every day. The fuel gauge and speedo are intermittently erratic as well, but I'm not sure that's a related problem. The power windows are slow, but they work, as does everything else electrical right up until the 90-day battery failure. She's dead in the driveway right now, and I'm tired of changing batteries. Any ideas?
connect the tester to both terminals, hold the switch for 10 secs and see if the batt drops below 9.6.
connect the tester to both terminals, hold the switch for 10 secs and see if the batt drops below 9.6. see post #4.
Have you checked the voltages after driving the car for a couple days to see how they compare to a just charged battery? If the battery is drained down to 12.0V do you still get 13.8V when it's running.
I replaced the voltage regulator, the brushes were worn out on mine. It was pretty easy to do and much cheaper than a new alternator. |
Had the same symptoms with my 125,000 mile 944. First clue was a very dim alt light on with all accessorys running. Old school mechanic sez...one bad diode in alt. He was right on the money. Replaced diode all better now. Good luck!
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
Don't get a rebuilt ebay crap. I bought one of them and the damn thing is only putting out 12.7V.. Which reminds me. I need another alternator.
dolor et pavor Copyright |
Hey Az_porschekid. did you're alt have an adjustable voltage regulator?
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
