-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   High compression (http://forums.pelicanparts.com/showthread.php?t=53695)
eligunn 12-05-2001 02:01 PM
High compression
I did a compression test on my car and it came out quite a bit higher than the 145 psi low tolerance limit. It said in the instructions that it could be carbon build up. Has anyone else had this experience?
Blackfoot 12-05-2001 02:12 PM
what is the year of your 944? and what were the readings?
<img src="http://home.pacbell.net/nirky/turbo_120usa.jpg">
3sonfather 12-06-2001 09:57 AM
Consider yourself lucky. :)
eligunn 12-06-2001 01:57 PM
88, the readings were up around 180 or 200
Scott R 12-06-2001 02:09 PM
Congratulations! Those are great numbers! I think the 145 range is too low. Haynes says 145, but many members here say those numbers are incorrect.
eligunn 12-06-2001 04:42 PM
Great thats what i was hoping!
Blackfoot 12-06-2001 05:18 PM
18/19 x 10.2 = 184/194
you are within spec i think.
marksportcts 12-06-2001 06:59 PM
Isn't the compression supposed to be the atmospheric pressure times the compression ratio?
9.7x14.7=142.6psi
Blackfoot 12-06-2001 10:08 PM
no. check what <a href="http://www.devek.net/index.php?page=nfo_tech_tips">devek</a> says about cylinder compression as it relates to compression ratio.
<img src="http://home.pacbell.net/nirky/turbo_120.jpg">
josh912 12-07-2001 10:02 PM
You're the first person that I've know to be worring about too high of compresion. Its when you get the 100 psi or the dreaded 0 psi, when you start to worry.
eligunn 12-08-2001 08:10 AM
I wasn't worried, I was just wondering if it meant that there was alot of carbon build up in the cylinders.
