Last year I bought an '87 944S primarily for use as a PCA DE car, although I also use it as a weekend driver. The suspension has been upgraded with Koni coil-overs and camber plates and it has been corner balanced, so it handles very well. Sparco Evos and 6-point harnesses were installed 2 months ago. Now I need to look at upgrading the wheels/tires. It has the original phone dial 15 inch wheels with the standard tire size 215/60-15 and Michelin Pilots with good tread remaining. I am in the Blue run group and would prefer to go with high-performance street tires. Should I buy a set of 16-inch wheels or stay with 15-inch and what brand and tire sizes are best? The tread width of the 215/60-15 seems too narrow for optimum traction.
AKA J BERK on Rennlist
I can tell you what I will be doing with my S2.....
I have put together a spare set of 968 5-spoke wheels...all 8". Planning to get a set of high-perf dual use (eg: street legal) dry weather tires like Dunlop Dirrezas which will go on these wheels...225/50/16 will probably be what I run all around. They will get pulled to the track on my tire trailer and I'll keep my D-90's with Khumo all-seasons for the street.
Joe Current: 2014 Cayenne S Gone but missed: 2003 996 C4S; 1991 944 S2; 1984 944 NA |
Az 944 Spec Director
944 spec cars run 225/50 R15 on 15x7's on all 4 corners. This nice tire size for the car and the tire prices are reasonable.
The downside is that these tires are small for a stock 944. They don't fill out the wheel wells very well. If you lower the car alot (about 2-3 inches) then they work well. For a dual use car the best look is 16" for the street and 15's for the track.
Joe P. 88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White Arizona Region 944Spec Director Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09 4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up) |
Porsche- Gulf 21_____ look down this page there is a tread call (tire suggestion ) byThunder-71 migth help.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
That Guy
Joe, i would run 245/45/16 (or a 40 profile) on your S2.. 225 is too narrow but good for the regular 8v n/a.
I ran 225/45/16 on all for corners when i auto-x'ed and DE'ed my n/a , worked very well for me and plenty of tire options available.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
