LonyB's Avatar
Release bearing help needed.
I can't seem to find a diagram or clear picture of the release bearing assembly.
How many rings in a release bearing setup, I have a total of 4, 1-Thin narrow, 1-multi-tooth, 1-thick, 1- C-Locking. is this correct?
Thanks for your help.
Old 04-19-2010, 12:45 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
By a search of this forum one can find almost any thing ...
http://forums.pelicanparts.com/porsche-911-technical-forum/290135-how-remove-throw-out-bearing-retaining-ring.html#post4118892
It is correct to have four shim/retaining parts with the Throw Out Bearing -
They are installed a certain way - the serrated shim has to be facing the correct way also...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 04-19-2010, 03:50 PM
