| wild man |
04-23-2010 02:53 AM |
Originally Posted by Techno Duck
(Post 5310258)
Getting it out is a major pain in the ass, but it can be done without disconnecting any of the coolant lines. I hate that plastic duct with a passion but it extends the life of the alternator ten fold. I just completed my a/c delete yesterday.. plenty of room under the turbo now.
No way I can delete my A/C. I have problems dealing with excessive heat situations. Boy, it's like 5:30 in the morning right now, and I can hear birds starting to chirp. I woke up from a nightmare in which 3 people I knew fell to their deaths ( I was one step away, but managed to stop in time), and I could not get back to sleep.
Anyways, the job still isn't done. I did get the alternator out, but I don't think it would have been possible without a air ratchet, as there are many places where you simply don't have the room to swing a manual ratchet back and forth. But the job still sucks, regardless. And I thought I was just going to put a VR for another alternator into it. But then I decided to replace the whole thing, in case the problem was a shorted coil, or a blown diode.
I got held up by some unrelated things I had to do yesterday, and by the fact that the cooling cone gasket was in pieces, and I had to make a new one. After making one out of some gasket material that I had, and started putting the replacement alternator in, I realized that the cone needed a very thick gasket in order for it not to leak. So I had to make a run (on the bike) to the auto parts store for some thicker cork material.
That is where the job stands right now. All I need to do is make a new gasket out of the thicker material, and put the alternator back in, and I'm done. Sounds pretty simple, doesn't it? I wouldn't count on it though. But I do need to get it done today, if I want to make hershey tomorrow.
