Battery Wires
Ok so I have just replaced the engine in my 86 944 n/a. There are wires that come from the battery through the firewall. One wire from the negative terminal, I assure gets grounded to the engine? The other wire that comes from the positive side I need to know where that connects? Does it go to the back of the starter and if so where on the back of the starter. In the searching that I have done I assume there is only suppose to be 3 wires to the back of the starter, one wore comes from the alternator the other is a ground and there is one other wire that is just connected to the starter????
Have a diagram or some pictures of where these wires from the batter through the firewall are suppose to go????????
