-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Switching ECU'S (http://forums.pelicanparts.com/showthread.php?t=540637)
bobe 05-04-2010 12:33 PM
Switching ECU'S
Would an 86 NA ECU work on an early car (84).
zedsn 05-04-2010 02:55 PM
Yes, but I believe that you would have to put in a newer AFM in as well.
krystar 05-04-2010 03:09 PM
yup. AFM and the DME (what the ECU is called on these cars) need to be same generation.
thekidd 05-04-2010 04:36 PM
have an 86 ECU and AFM in my car now. Its good to do if you track the car because yuo can chip it easier with better chips. It also stops the "idle stumble" on the early modles where you rev the car and then drops to 600 RPMs, latemadels dont do that.
Tiramisu 05-05-2010 08:51 AM
Any other benefits to adding a late ECU to an early car besides chipping and idle stumble?
krystar 05-05-2010 10:34 AM
removes weight from your wallet so you go faster?
smokin_944 05-05-2010 03:59 PM
lol...
