84 944 Ignition Stays on After Key's Out
1984 944
Bizzaro.....Just dropped $600 on new tires, $1,400 on rebuilt tranny, polished the baby up and went out on a nice cruise today to enjoy the hint of spring in the air, and voila, got home turned off the key.......and the car keeps running!!!!!!
The ignition switch will not turn off. I turn the key to off, the radiator fan goes off, but the engine keeps running. I turn off the engine by reaching under the steering column and pulling out the computer plug. All the idiot lights stay on, and the chime bongs when the door is open.
Guess the ignition switch is dead. I tried sprayng it with WD40 and tapping/banging on it, but I can't get the ignition to go off. It starts fine when I turn it to starter position.
I found the ignition switch with keys here on Pelican, but how hard is it to pull the old one out and put in the new one?
Does anybody have step-by-step on an early model, or do I have to take it to my mechanic?
Thks! scott
Old 03-17-2009, 12:07 PM
Send a message via AIM to Icey1174
www.clarks-garage.com
Click on "Garage Shop Manual" on the left side tool bar. Click on the letter "I" for Ignition and you will find your step by step instructions. This is a great site. I, as well as many others, suggest you book mark this page.
Good Luck!
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 03-17-2009, 12:33 PM
Perfect, thank you! That's exactly what I need.
Was hoping it wouldn't be as involved, but I suspected as much b/c the Audi dealer charged me $600 in 1989 to replace my Audi 5000 ignition switch.
Hell, it's an ignition switch, if it was easy, it would be a field day for the criminals!
Just ordered the part from Pelican, so looks like my coming weekend is spoken for!
Old 03-17-2009, 12:58 PM
Glad I could help. this site as well as Clark's Garage are great resources!
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 03-17-2009, 01:59 PM
Its an easy fix. I just did it on mine last weekend.
$30 for the switch and about 4 hrs worth of elbow grease.
Be careful removing the plastic around the steering column. Being 24 yrs old its pretty fragile.
Life's short
Go fast
Have a blast
Leave a good looking corpse in a 84 944
Old 03-18-2009, 10:33 PM
Did the switch fix your problem?
1985.1 Porsche 944 (Progress Thread)
Old 05-14-2010, 04:42 PM
ernie9944's Avatar
+1 on being careful otherwise you'll end up with a bunch of broken plastic parts ,same when reinstalling take your time & be patience.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-14-2010, 05:57 PM
Just thinking out loud
mattdavis11's Avatar
Look for a vw switch, it's cheaper, maybe $15. Loosen the screws on the underside of the instrument cluster, you might need to buy some epoxy and tooth picks. That's worked for my broken bits. You can fix the switch if you want.
91 FJ80
84 Ram Charger (now gone)
Old 05-14-2010, 06:22 PM
Hello, If the ignition switch module wires pull out the link below will show how they should be repositioned.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/484663-ignition-switch-plug-wire-layout-87-944-na.html
Cheers,
Larry
Old 05-14-2010, 07:57 PM
