Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
OPRV - early 1 pc.
Hello all,
I have just removed my Oil Pressure Reducing Valve after noticing the oil pressure gauge has pegged a couple of times.
I have found that it wiggles just below the threads of the long top nut - is it supposed to do this or is it broken. If it is broken how/what should be done to fix it ???
Thanks all
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-13-2010, 08:19 PM
Redline Racer
HondaDustR's Avatar
The cylinder that contains the piston is retained within the nut cap with a rubber o-ring. It is not solidly mounted and will feel loose. The important thing is that the piston slides freely and does not look scoured. There should also be an o-ring on the end. The o-ring holding the valve together can be replaced by pulling the cylinder out of the bolt head, which can be particularly difficult if the o-ring has hardened with age. If it is separated, the o-ring must be replaced, since it usually gets destroyed in the process. The pressure sender may be failing. The guage will peg with a bad sender.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-13-2010, 08:29 PM
Garage Helper
Thanks HondaDustR - While I was at it I was going to replace the sender also.
I will take the OPRV apart and install new O'rings and a seal ring at the top.
"If you are not having fun don't do it".
Old 05-13-2010, 08:39 PM
