-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Rear Wiper Missing... (http://forums.pelicanparts.com/showthread.php?t=542975)
rrwebster 05-18-2010 03:47 AM
on my new toy I have a hole in the glass... and some wires (3) near the hole.
is this (see picture) all I need to have a rear wiper again?
http://forums.pelicanparts.com/uploa...1274179635.jpg
thanks in advance!
Robert
ernie9944 05-18-2010 04:55 AM
^^Robert why don't you simply deleted the rear wiper an use this wiper plug unless you realy want a r/w they come in two style;)http://forums.pelicanparts.com/uploa...1274183536.jpg
http://forums.pelicanparts.com/uploa...1274183635.jpg
rrwebster 05-18-2010 06:36 AM
Ernie,
I had thought about getting one of those but really want everything that's supposed to on the car in place and functional... like it was when it was new. These are really great little cars... I'm really loving it.
oh... btw I've found out that is all I need and have already purchased one.
Robert
Grandad#3 05-18-2010 07:22 AM
Before you install the new/used rear wiper motor drill out the rivets, remove the case and clean out the old caked grease inside and re-lube with white lithium grease. Check that the rubber seal is still soft on the shaft, so no water can get inside the cleaned up motor. Do a SEARCH and there should be a How To on here or on Rennlist.com.
Cheers,
Larry
rrwebster 05-18-2010 08:55 AM
Cheers,
Larry
Larry... Thanks so much for that advise... will be much easier to do before the install!
Robert
