-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Holy Crap Batman! Shredded Flex Damper Photos (http://forums.pelicanparts.com/showthread.php?t=545934)
Tidybuoy 06-02-2010 10:15 PM
Wow! & Unbelievable, comes to mind. I've been working on replacing my Flex Damper and I got the Torque Tube moved tonight so I can access the Flex Damper.
Here's some photos. It truely is Hump Day as I am exactly 1/2 Finished!
Old Flex Damper - Still on the Car. Torque Tube Dropped & Out of the Way:
http://forums.pelicanparts.com/uploa...1275541549.jpg
What's Left - Outer Section Just Fell Right Out
Notice the little metal ears, that's what got me home as they were clacking
against a matching set on the auto-flywheel:
http://forums.pelicanparts.com/uploa...1275541618.jpg
Old vs. New - Front Side:
http://forums.pelicanparts.com/uploa...1275541688.jpg
Old vs New - Back Side:
http://forums.pelicanparts.com/uploa...1275541822.jpg
cvriv.charles 06-02-2010 11:48 PM
Your installing a new rubber center instead of a spring center?
Tidybuoy 06-02-2010 11:55 PM
Yes, this the a flex damper for an automatic transmission.
flash968 06-03-2010 05:11 AM
if only they made a beefed up version of that - the 968 tip has the same dumb thing - they age out and shred just like yours
wild man 06-03-2010 06:27 AM
That's exactly what happened, way-back-when, on my (lightly powered) 77 924 automatic. I think that setup (rubber flex-plate) was one of porsches worst ideas.
Tidybuoy 06-03-2010 09:27 AM
Well, now that I've been thru the process....I'm going to be on the hunt for a manual trans and all the necessary parts to convert. I'm kicking myself because when this happened, I saw an '88 with a broken timing belt for $2k on Craigs List (only 70 or 80k miles & local).
Anyway, now that I've seen how it's done, it's really not that bad....just a little time consuming.
running_cold924 06-03-2010 11:22 AM
some of the older street bikes, like GS 1000 had a hard rubber rear sprocket for a "smoother" ride. they do shred when you dump the clutch though.........
WaA420 06-03-2010 05:54 PM
Yah, I think you can put a spring center clutch in place of that damper. Problem solved.
flash968 06-03-2010 09:57 PM
if only - i'd love to see it though
Tidybuoy 06-04-2010 12:28 AM
In the next year, I'm going to acquire all the parts that I need to convert to a manual trans. I love my car but I hate the fact it's an automatic. After doing this job, I can see that converting will not be too difficult.
indio76 06-04-2010 06:18 AM
...I follow with high interest your posts, thanks for pics...they will be useful to me...
Don't understand why, after all this job, you want to convert to manual!?:confused:
cvriv.charles 06-04-2010 06:49 AM
Manual is better:) And as to why he decided after the job,... who cares:) Manual is better:)
Tidybuoy 06-04-2010 09:12 AM
I want a manual for the fun-to-drive factor. Yes, it may be a waste of money after doing this job but it is the "doing" of this job that has taught me that it's not that difficult to do.
Keep in mind, when I say a year, it will probably be three :). Shall I post pictures of some of my other unfinished peojects...
Slam 06-04-2010 09:23 AM
Hmmm. Too bad you can't get a Trojan damper. They seem to know about rubber...
looneybin 06-04-2010 10:36 AM
it could even have ribs for "her" pleasure
Slam 06-04-2010 10:40 AM
If she's the driver...
looneybin 06-04-2010 11:12 AM
"she" is the car - it IS an automatic afterall, just kidding Vern
Schumi 06-04-2010 11:50 AM
I looked at those pictures and honestly did not know what I was looking at.
I've never seen nor worked on an automatic 944. And I never want to.
WaA420 06-04-2010 03:18 PM
If anyone else on here needs to replace there damper just put a used 944 spring center clutch in its place. Lots more affordable.
flash968 06-04-2010 03:28 PM
i sure wish that worked on the 968 - unfortunately the things don't fit
