Speedometer and odometer not working
I have a 944s2 and the speedometer and odometer is not working. I replace the plastic gear and still doesn’t work. Any suggestion on what the issue might be?
Administrator
Hello and welcome to the forum! Take a look at the link below to one of our site's DIY tech articles. Hope this helps you a bit in troubleshooting.
https://www.pelicanparts.com/techarticles/Mult_gauge_repair/mult_gauge_repair.htm |
If both the speedo and the odo are not working, it is most likely the sender on the transmission, or the wiring between the sender and the gauge.
Good luck, George Beuselinck |
Mine did that at one point. I got a replacement cluster off of ebay and replaced the speedometer. So, it was something in the actual speedometer that broke, not the gear. The gear did eventually break, just replaced it this weekend.
2010 Cayenne GTS |
Make sure your speed-sender in transmission is working as well as wiring in between.
Need to actually TEST parts and confirm they are bad before replacing. Otherwise you're gonna be replacing A LOT of perfectly working parts with brand new perfectly working parts and nothing changes. |
Also your year might be important, I know the 1991 S2 has some commonality with the 968, which uses the ABS system to generate the speed signal. I do not know if the S2 does this but I think it does have a different ABS brain.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
