Easy cab top safety bypass
This allows you to raise/lower the top while the engine is running.
In the fuse box, remove relay G21, jumper pins 1 to 2, and pin 8 to ground. I drilled a small hole in the case and attached the ground there because I could not find a ground on any unused relay sockets. G21/pin 7 reads ground when the key is off, but reads 40ohms when the key is on. ![]()
'90 944S2 cab - sold after 20 years, will not be forgotten. '04 Mercedes SL500 - Nice but my S2 was more fun to drive. |
all you really needed to do was cover or disconnect pin 6 of the relay
i ran that way for a long time - then i got freaked out by so many broken bow nightmares that i went into manual mode - much faster, and no chance of a motor wigging out and snapping a very expensive bow and ripping the top Last edited by flash968; 07-28-2010 at 05:21 PM.. |
Yup, I just tried it, covering pin 6 works. How did you discover that?
lol - i can't take credit for it - i got it from a DIY on 968forums.com
Welp, it's certainly much easier than my trick, thanks.
no worries - happy to help
That makes no sense. There are no fuses being bypassed the way I did it.
Location: In a dumpster behind Albertson's in Los Angeles County
Oopppsssssss....my bad, that comment got posted to the wrong thread.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
