Horn not working
The horn isn't working and I was wondering which fuse is for the horn and which relay is used for it as well. If there is anything that I should look for, let me know.
Mark '83 Porsche 944 NA '90 Porsche 944 S2 |
Cars & Coffee Killer
I had the same problem--both of my horns had rusted.
I'm not sure of the fuse number on an '83.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I'll take them out and check. This car has been sitting for 5-6 years and I have been fixing things for weeks now. I completely forgot what a fun car this is.
Mein Gott!
Yeah, I just had the same issue. Relay and fuse was fine. Turns out both my horn units themselves were shot. Find the cheapest used ones you can find in the 944 parts section of this board. Easy fix.
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
My favorite replacement horns:
![]() $15 at Harbor Freight.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I was thinking of getting the Griott's 135 dB air-horn myself. I can't tell you how many times I have nearly been run of the road by people in minivans or SUVs, talking on their cell phone with their left arm wedged against the window, who start to veer into my lane because they didn't look and my car is "underneath" their peripheral vision...
look at the relay panel near the fusebox. the relay with a red fuse attached to it is the horn relay. it's in the bottom row, 2 or 3 from the right.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Let's go shooting.
There's a ground off the steering rack for the horn that screws to the chassis cross member that often gets corroded.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
horn pic where it gets corroded
can you post a pic of where the typical corrosion for the horn occurs?
