Brake Fluid Guru
86 951 Wheel Bearings
I recall on my 93 968 they were VW part numbers for the front wheel bearings. By using the VW part numbers I was able to save quite a bit on the wheel bearings.
Does anyone have any suggestions/part numbers for the VW equivlent wheel bearings for a 86 951? Thx Michael
Michael |
In the Fires of Hell.....
OEM wheel bearings for the 944 are pretty cheap already (Look on Pelican for yourself). I would just go that route, as you are only going to save maybe $5 total...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Toofah King Bad
Plus the 951 ones are beefier than NA. . .unlikely to have VW equivalent.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Brake Fluid Guru
That doesn't make sense as the 87 - 95 951, 944 S2 & 968 all use the same inner an douter bearings and those are readily available as a VW part. No difference at all.
Michael |
Toofah King Bad
Cool, after you look into it, you can let us know what you come up with.
I just went to a local parts store for mine--bought some Made in USA (no kidding) Timken's and seals for under $40.
~Chris 1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear 1993 Jeep Cherokee - 3" Lift, 30" tires |
Brake Fluid Guru
Using which part numbers?
Michael |
I used the front wheel bearings that i had bought for the N/A on the turbo. I remember one of them were FAG. I bought them at auto haus..
dolor et pavor Copyright |
Looks like SET2 and SET6. ********.com has them for $4 and $5, respectively. Not sure about the p/n for the seal.
