944 ac relay
First time user here-. I need to replace the ac relay on my 1987 944 but it is "stuck" in it's housing. Short of putting a mechanical jaw on it, I cannot get it out of the sockets. I see and can feel no side clips. Could the prongs be rusted in? I have pulled other relays in the past and no problems . Any ideas?
Old 07-10-2010, 05:38 PM
Griffinroydonal's Avatar
Stuck relays
I have used a paint can opener with the small hook to pull stuck relays. The top will come off if you pull with your hand.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 07-10-2010, 07:01 PM
ernie9944's Avatar
You migth want to try to get W-40 in there & let it soak for a while or if you can find a cane of (Prolab PL-Bio)penetrating lubricant the stuff is biodegradable & will work wonder,in both case "let soak & repeat if needed.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 07-10-2010, 07:04 PM
If you spray any of that stuff DISCONNECT THE BATTERY FIRST.
Cheers,
Larry
Old 07-10-2010, 07:39 PM
The idea of using the paint can opener to pry up the AC relay worked!! .. it was really stuck in the sockets (5 prongs)but no signs of corrosion -- just a tight fit I guess.
Old 07-11-2010, 03:19 PM
Used a flathead on mine, battery already disconnected, wasn't very easy, I had to go at it from one side, then switch to the other side of the relay, to lift it evenly.. I'll have to check my old PC repair stuff to see if I still have the eprom puller. Looks similar to the paintcan opener business end, except it has a wide jaw with two lifting tabs, just might do the trick.
"porsche it's an institution"
Old 07-11-2010, 09:11 PM
