cjpacitto's Avatar
Anyone familiar with Steering Pressure Switch on 944S?
Working on a 944S engine to transplant into my n/a. Came across a power steering pressure switch that only the S model seems to have.
Pelican Parts - Product Information: 944-606-209-00-OEM
What is the purpose of this? Does it sense the pressure being too high or too low? Does this trigger a light in the dash?
Where does this switch go? The parts diagrams just show it off by itself and I can't find any other info. I'm guessing it may go into the extra port on the steering pump that is usually plugged.
Any info would be greatly appreciated.
Old 07-24-2010, 05:10 PM
Hi, Read the link posted below. Make sure you separate the wires and tape them up good.
944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast.
Cheers,
Larry
Old 07-24-2010, 11:35 PM
cjpacitto's Avatar
Thanks Grandad, that is exactly the info I needed!!!!
Old 07-25-2010, 05:18 AM
that switch originally was there on the 16 valve models to send a signal to the dme control unit to increase the idle speed to the idle air stabilizer valve when steering was at maximun pump pressure . when steering rack was at full lock right or left.
Old 07-26-2010, 12:54 AM
