-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Turbo twist wheels (http://forums.pelicanparts.com/showthread.php?t=554067)
ERN911 07-19-2010 12:32 PM
Turbo twist wheels
Can someone tell me if Turbo twist wheels 7.5x18 et50 and 10x1/8 et65 fit an 86 944Turbo
thanks
Ernie
racer 07-19-2010 01:10 PM
Not without a lot of work. '86 year cars are "early" offset wheels.. Something in the 10-23mm ET.
The wheels you found are "late offset" or something in the 50-65 ET range. You would have to figure out how large an adaptor/spacer you would need to make it fit. Then you might have to , at least on the rear, worry about rideheight and alignment and maybe trim fender lips to make them work.
badcoupe 07-19-2010 05:32 PM
you need spacers the thickness of the difference between offsets, I had to do this my old forgelines.
