"Dude! You kicked my car.
Sway Bars Question
So I have an '87 944 NA and right now the handling is garbage. Lately I've been doing quite a bit of autocross with the car so I'm trying to improve the whole suspension one piece at a time. Right now I'm looking for sway bars. My car didn't come with a rear one so I definitely want to get that but, I also want to upgrade them to much larger bars to reduce the unholy amount of body roll my car gets.(see pictures below) Anyways I just found a good deal on a front M030 sway bar and I think I can get a rear one for a reasonable price. My question is what else would I need to put these sway bars in my car? I know I'll need bushings for the front and rear and drop links for the rear but what else do I need?
Certified Porsche addict
Koni Sport adjustable shocks front and back would help. Lower the trailing arms in the rear and install 1.5" 200-250 lb. lowering springs in the front. If you get the rear 18 mm 3-way adjustable sway bar that's part of the M030 package, the 30 mm front sway bar might be a little too stiff. I've done all of the above and got a little more understeer than I'd like to have.
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 |
To mount the new bars:
For the front, you will need a larger retaining bracket, along with the larger bushings. Get the cheap triangulation braces too. For the rear, you also need the bushing straps and the drop link mounting bolt, which should come with the bar since it is NLA, at least on Pelican. My used bar came with them. I just did the exact same thing, adding a rear bar and upgrading the front, though not to the M030 set, just the late 80's turbo size. It made an quite a difference in corning, where before I was understeering quite badly, now I am much more neutral, with a hint of overseer with the throttle. I will probably put in a slightly larger front bar for a little more balance. BTW, I also just put in a strut brace, and that also helps noticeably in hard cornering.
1985.5 944 NA 1972 Triumph GT6 1982 VW Westfalia 2003 F150 Supercrew 4x4 1988 F350 Regular Cab 4x4 |
I always wondered if those strut braces actually work. Maybe I'll get one at some point during my suspension upgrade. |
I have the 30mm front sway bar on my car and it is from the 968 as well as the m030 rear. I think it was one of the best improvements I've done.
I had alerady added Koni's, stronger front lowering springs, adjusted the rear height to match the front, and Turbo 16" rims. When I added the 30mm bar, to my surprize, the ride comfort improved substantially, even on the straight aways. Even though the sway bar is primarily for the turns, it helps on straight pavement too because not all bumps are on both sides of the car. The 30mm added much more control to the entire ride and handling and really eliminated the ride harshness that came with the addition of Koni's. I would recommend getting the triangular front swaybar brace as I hit a serius pothole onetime and snapped the stock bracket in 1/2. |
How much does it usually cost to get the torsion bars reindexed at a shop? Cause I'd definitely like to lower my car a little
oof!
IF you can find a shop who will do it, you are looking at about 8 hours of labor, but be prepared for it to be more, as most people miss the first time on how many teeth to move it, and guess who gets to pay for the time to correct it best suggestion would be to get a firm price, and not let them do it by the hour if the eccentrics don't lower it enough, and you can't live with it, get the checkbook ready p.s. you get to do an alignment afterward too rough guess would be about $1000 to do the job |
take this one step at a time
do the sway bars first, then shocks and sport springs in the front, by that time you will have a good idea as to where you still want to improve your suspension I say sway bars first because they are the easiest to get out of the way, and you will do them eventually anyways, so might as well get that out of the way get good shocks - either koni or billstein hd's, autocross springs in the front, drive your car for a little bit and see if you still want even more improvement everyone wants a different thing out of their car, some daily their car and autocross, while others just autocross, and others have "race" cars - and they all value improvement in response differently, because some cars are daily driven while others are not once you see what makes you happy, you can decide if you want to do torsion bars, or switch to rear coil over system this way you don't dump a whole lot of $$$ at the same time, and you get to do everything in a nice progressing way - you learn more about the car, and what improves and where improvement still needs to be done and also, HOLY body roll! especially that rear 3/4 shot! wow! & also, don't be afraid to start with softer spring first, you will always find a buyer for a used 200-250lbs springs, and they happen to be a pretty good match to stock torsion bars, so if you still want to go "lower" and "stiffer", it won't cost you an arm and a leg good luck! this is what I'll be doing ... |
I guess I'm getting a little ahead of myself talking about springs and reindexing my torsion bars. You're right I should just be taking this one step at a time otherwise it gets pretty overwhelming pretty fast.
So, back to the sway bars. Now that I know what to get to install them what size rear bar should I get? The front is 26.5mm so what should I do for the back to get a good balance and avoid getting too much oversteer or understeer? |
Toofah King Bad
Fattest one you can find. I recommend the 968 M030 unit, 19mm adjustable, still available new from PCNA at a reasonable cost.
ť 1987 924S Turbo - Got Boost? Ť "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
i got a used 18mm rear bar for my 26.8mm front bar.
to fit it i bought drop links secondhand from dcauto and a rear swaybar adaptor kit from paragon Porsche 924S and 944 Rear Sway Bar Adapter Kit.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Lindsey Racing sells a 19mm that is 5way adjustable.... For $120... It made a monumental difference on my car going from a 13mm to the 19mm....
or, you could go with Weltmeister sway bars, 28mm front and 22mm rear, they are expensive though, VERY you can find a good deal on the 18mm rear sway bar, they are pretty cheap compared to 19mm sway bar, and again, if later on you want to go bigger - you will pretty much always find a buyer for this one, so don't be afraid to experiment a little |
I found an 18mm rear sway bar locally. The guy said he wants $100 for the bar and hardware. I think I'll go check that out tommorrow.
Does that sound like a fair price? I figure the hardware usually costs around $90 and an 18mm sway bar's usually about $85. |
does that include droplinks?
try and get new bushings still if you can.
it all comes down to what you plan to do with the car - reducing body roll is not always a good thing - in autocross, it can actually cost you time - further, if you don't have the springs to handle it, it is easy to overbar the car - it's all a balancing act
from the shots, there is more roll than desired, but as soon as you reduce it, you will begin to find that those tires are too small and too tall, and that may be a slippery slope you don't want to go down that being said, the 968 M030 bars are decent for spring and wheel rates up to about 275# front and rear wheel rates of about 275 - after that, you need bigger bars for a track car, but can still get away with those on street cars a less expensive improvement would be to grab a set of standard 968 bars - they can be had for nearly nothing - the front will be 26.8mm and the rear will be 16mm - typically a set can be had for less than $200, complete with bushings |
Well I got that 18mm rear bar today all ready to go in the car for $100.
And as a plus when I left the guy's house I found some crazy winding roads. So me and my friend played around on them for a bit. Me in the 944 and him in his E36 325is. But I can't help but feel ripped off cause I had the bar right there in the car and I didn't feel any diffenence in handling. I mean it was right there in the trunk the whole time. LOL JKBut seriously now I just can't wait to get my front one. |
it's all about weight transfer and the timing thereof in the transitions of turns - if the bars are too stiff relative to the suspension, the car will skate like it's on marbles
in autocross this happens all the time - i constantly see guys over-barring cars, and ending up with both understeer and snap oversteer on the same car typically in autocross i either disconnect the front bar, or go with a small one - the rear i set up to be barred stiff but sprung soft - but then, i don't use the bakes much either, and steer with the rear of the car a lot this setup would be a mess on a road race course though, and not much fun in a canyon setup is tricky stuff, and with a dual purpose car you have to make compromises - if it's dedicated car, you can tune much better - heck, we used to change gear ratios, depending on the course, just to get the right exit launch |
