CV-joint. Need to know orientation of seperator
I messed up when cleaning my CV-joints. The paint I used did not stand up to the cleaner, and now I no longer know which way the separator should go in.
One side has a larger bevel than the other. I'm guessing this bevelled side goes towards the half shaft, but I would like to be certain. Generic, non-944 CV-joint.
1990 944 T: 100 000 km/63K miles, 1997 986 2.5L: 95 000 km/60K miles, Living in the trackless land of plenty! |
Toofah King Bad
Yikes, raise your hand if you never noticed this!
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I should off course make it clear that this is for a 1990 turbo.There may be some differences to earlier joints.
1990 944 T: 100 000 km/63K miles, 1997 986 2.5L: 95 000 km/60K miles, Living in the trackless land of plenty! Last edited by bebbetufs; 08-11-2010 at 12:23 AM.. |
The larger bevel is towards the inside, where the boot goes.
I just did take the CV joints off the 968 Tip and ordered new ones. I went to the garage to look.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
That's what I thought.
Thanks for looking!
