engine vibrating
i changed water pump, oil cooler seals on 1983 944. runs great, but engine in now vibrating. could it be balance shafts not set currect. idles fine. thanks steve
Old 08-20-2010, 06:41 AM
Proprietoristicly Refined
John_AZ's Avatar
If it did not vibrate prior to changing the WP you may have the lower balance shaft pully upside down.
Here is a picture and notice the dark spots on the top of the BB shafts--these are the "shaft Key slots" and they have to be in positions shown. Notice the "U" & "O" on the pullys.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-20-2010, 06:53 AM
porscha
matty89's Avatar
GL
John
thnx all remember that for when i put mine back together ! u on top O Buttom and aligh it!
Old 08-20-2010, 06:57 AM
o.k going to take apart and ck. thanks
Old 08-20-2010, 07:01 AM
John_AZ's Avatar
matty89,
Bottom & Top----Right and Left BB pully "U" & "O" are reversed. THAT is the secret
Old 08-20-2010, 07:57 AM
matty89,
Yep, U for unter (lower) and O for ober (upper). Remember, a U-boat was under the water.
Good luck, George Beuselinck
Old 08-20-2010, 08:21 AM
or if u don't want to learn 944ecology german..
just remember Over and Under hehe
Old 08-20-2010, 10:05 AM
