Hey
Just wanted to say thanks to all you folks. For the help with "The Project" ( yes I'm married), which started as a cam tower oil leak and morphed into : Remove, clean and paint cam tower. Black with polished letters. Clean and paint intake manifold and all the associated brackets. New fuel injectors. Replace ALL vacumn hose. Replace fuel damper and regulator. Replace fuel hoses. AND the part that made the Ice Princes(yes the 924 was a cold blooded B***H) run the best was a $14 dollar temp sensor........... But it was fun. Thanks again for all the info, insight, and humor. Later Mark
1988 924S It's still cheaper than psychotherapy................... |
Proprietoristicly Refined
Mark,
Stick around. Pelican can always use experienced members. N.E. WI. The 'ol days. Stout, bars, Eau Claire... Welcome & GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Just thinking out loud
Those pesky cam tower gaskets! They can turn a non eventful day into quite a rush, leading to weeks worth of fun. Glad you got it all sorted out.
83 944 91 FJ80 84 Ram Charger (now gone) |
Umm, Eau Claire is Northwestern Wisconsin. Green Bay would be NE.
81 931 -efi via some megasquirt stuff |
--![]() Meant to type N.W.
NE WI closer to all the fun at Road America
88 944 na 07 335i 12 Cayman |
Mat
I read your thread. I was very lucky that my gasket failed very close to home. Good that yours wasn't worse................. and for the geographically challenged...find Green Bay...thats N.E. Wisconsin. and there's some fun at R.A. this weekend...the autumn vintage festival. Mark
